I own a 2015 2.2 diesel cx5. Engine light came on and code p2262 (turbocharger/supercharger boost pressure not detected-mechanical). Anyone else had this problem before?
The MAP sensor?Hello.Change the exhaust pressure sensor.
Thank you, will check it out.No.exhaust pressure sensor.search on google the sensors that we have on our engine and you will find where it is
Hi All, Not so much for the original requester, but for others who come searching for the same reason. My 2017 CX-5 2.2D skyactiv had the Check engine light come on and a loss of power. The OBD-II scan presented code "2262 - Turbocharger/Supercharger Boost Pressure Not Detected" Based on the comments here I took it to the Mazda service centre armed with the information that this is a very common issue for the 2.2D skyactiv. When dropping off the car, I said politely that if it is what I think it is then I think it should be repaired under warranty and the service guy said 'You think it is the exhaust pressure sensor?" which indicates to me they get more then their fair share of these.I own a 2015 2.2 diesel cx5. Engine light came on and code p2262 (turbocharger/supercharger boost pressure not detected-mechanical). Anyone else had this problem before?
Thanks for the report. I guess the next thing you want to watch is the overheating without warning which could blow your cylinder head gasket on your 2.2L SkyActiv-D diesel.Hi All, Not so much for the original requester, but for others who come searching for the same reason. My 2017 CX-5 2.2D skyactiv had the Check engine light come on and a loss of power. The OBD-II scan presented code "2262 - Turbocharger/Supercharger Boost Pressure Not Detected" Based on the comments here I took it to the Mazda service centre armed with the information that this is a very common issue for the 2.2D skyactiv. When dropping off the car, I said politely that if it is what I think it is then I think it should be repaired under warranty and the service guy said 'You think it is the exhaust pressure sensor?" which indicates to me they get more then their fair share of these.
Anyway the extra information I wanted to add is that on picking up the car a different service guy said that it is a different/new part that has been fitted and that Mazda have extended the warranty on the original part to 10 years/200000km. (Probably a condition on being allowed to not have to do a recall for a known issue) As a result the repair was completely under warranty at no cost to me. ( This is Mazda Australia for anyone interested)
Many thanks to those before me who contributed to this forum with the information that I needed to diagnose it quickly.
