Code P0451 EVAP
Mazda 5 Sport 2012
my CEL came on the other day and the code I am getting is P0451 - EVAP System Pressure Sensor/ Switch Circuit Range/ Performance. I have notice it is burning more gas. When I look up this code most peoples solution is to replace the Tank Pressure Sensor TPS but from what I can see is that the 2012 Mazda5 does not have one. Do you think it might be the front or the back Canister Purge Valves parts LF82-18-740 or LF3T-18-741? Has anyone else had this problem? Here are some readings from my OBD2 reader.
Screenshot_20190206-223046_BlueDriver.jpg Screenshot_20190206-225233_BlueDriver.jpg Screenshot_20190206-225245_BlueDriver.jpg
Mazda 5 Sport 2012
Looking again today I think I my have found the sensor part CG36-42-580A. But still has anyone else had this problem?
2009 Mazda 5 GT
It could also be the purge valve solenoid, pretty sure it's located under the hood no drvr side of engine. No personal experience but there is a specific method of testing it out that involves blowing through it to see if it's clogged or not.
Would be easier to rule that out than to drop the tank and replace the sensor only to find out your problem was the purge valve.
Mazda 5 Sport 2012
ok, sounds right. I wonder if you could just blast out that sensor with carb cleaner?
Possibly
The hose and sensor came as one piece so I didn't look to see if the sensor could be removed by itself with out damaging it. The hose has one time snap lock on all the ends so once it's off it has to be replaced.
cnoland
US Air Force
2012 Mazda5
Was this issue ever resolved? I am in the same situation and want to be sure that the CG 36-42-580a fixed the issue. Thanks
