clutch Problems
ok so i recently took my car in to get the manual transmission fluid changed ( as per the manual) and about 2 days later i began to have problems with shifting into second gear. i only have about 72,000 kms on it so i wouldnt think it would be the clutch.. anyone have any ideas before i take it in?
mazdaddy
Capt. Slow
Laser Blue 2003 Protege 5, Midnight Blue 2001 Miata
Could be the 2nd gear syncro (have you tried "double clutching"?),or there is an issue with the shift fork.
i know that the fluid that was used was correct ( i looked while i was there and they put in the one required by the manual) and i had the level checked also.. and yes i can double clutch but as cool as that sounds.. honestly who really wants to HAVE TO do that? i just want it to drive nice and normal
mazdaddy
Capt. Slow
What I meant is, that if it shifts for you when you double clutch, it's probably the syncro that is the problem....
sorry about that then.. i just am defensive about people replying to things without thinking.(i'm sure you know what i mean). i apologise again as you are not one of them.. im quite sure it is the synchro after talking to a bunch of people about it and i made an appt on saturday to take it in ( good thing i got the extended warranty)
Top
