justanothermp5
Banned
- Rust Bucket
Alot of people on here ask about torque specs for engine components, and you cant really find it anywhere online so i figured i would post this stuff for everybody's use
(Plus i had to type it up for a friend anyways lol)
*Cylinder Head*
Assembly: Looking at the top of the head, front of engine on left
(8) (4) (1) (5) (9)
(7) (3) (2) (6) (I0)
-1st Step: 17.2-22.0 Nm (2.7-16.2 ft lbs)
-2nd Step: tighten another 85*-95* in order
-3rd Step: tighten another 85*-95* in order
*ARP Head Studs*
-Tighten in the above order
-Use ARP Moly Lube
-30 ft-lbs, then 60 ft-lbs, then 90 ft-lbs
*Cylinder Head Bolts Limits*
-Standard Length: 99.2-99.8 mm (3.91-3.92 in)
-Max. Length: 100.5mm (3.956 in)
*Camshaft Cap Bolt*
(19) (11) (3) (7) (15)
(17) (9) (1) (5) (13)
(18) (I0) (2) (6) (14)
(20) (12) (4) (8) (16)
Torque: 11.3-14.2 Nm (12.7-16.2 ft lbs)
*Main Bearing Cap*
Assembly: Looking at the crank, flywheel end on the right
(8) (4) (1) (5) (9)
-Torque: 54-58 Nm (40-43 ft lbs)
-ARP Main Stud Torque- 60 ft lbs W/ MOLY LUBE
*Connecting Rod Nut*
-Torque: 48-50 Nm (35-36 ft lbs)
*Pauter Connecting Rod Nut*
-Torque: 50 ft lbs
*Crankshaft Pulley*
-Pulley to pulley boss: 12.3-17.1 Nm (109-151 in lbs)
-Pulley Boss to crankshaft: 157-166 Nm (116-122 ft lbs)
*Flywheel/Flex Plate*
-Torque: 92-102 Nm (70.9-75.9 ft lbs)
*Oil Pump*
-Torque: 19-25 Nm (14-18 ft lbs)
*Tip Clearance
-Standard: .02-.018 mm
-Max: .22 mm
*Max. Body Clearance
-Standard: .09-.18 mm
-Max: .22 mm
*Side Clearance
-Standard: .03-.11mm
-Max: .14 mm
*Water Pump*
-Torque: 7.9-10.7 Nm (69.5-95.4 in lbs)
Thats it for the torque specs I have, if anybody has any i didnt list, let me know and ill add them to the list
I had to use an I instead of a 1 in the 10's or else this would show up (10)
The clearances will be updated in the next post, but it will take me a while to type them
*Cylinder Head*
(8) (4) (1) (5) (9)
*ARP Head Studs*
-Use ARP Moly Lube
*Camshaft Cap Bolt*
*Main Bearing Cap*
(8) (4) (1) (5) (9)
-Torque: 50 ft lbs
*Crankshaft Pulley*
*Oil Pump*
*Tip Clearance
-Max: .22 mm
-Max: .22 mm
*Side Clearance
-Max: .14 mm
*Water Pump*
