Spiced MSP
- 2016 Peterbilt 579
ok, my car started leaking coolant recently and I found out my water return elbow was leaking. So, I drained the system and replaced the elbow. Started the car and filled with coolant as needed with the heat on full blast. After I topped off the radiator and the overflow, I let the car run with the radiator cap off to get rid of any air pockets, shut the car off, let it cool down and checked the coolant again, repeating the process. Now, the car ran fine for a day and a half before the temp gauge started to rise again. I could drive with the heat on and the temp would drop. Then, it would get to the point where the heat wouldn't do anything. So, I would drive with the AC on so the AC fan would turn on and that would work. Everytime I let the car idle with the rad. cap off, the car is fine for a day and a half. I have replaced the thermostat, radiator cap, drained the system and filled with new coolant. My car has around 76000+ miles on it, so I hope it's not the water pump and I don't think my radiator is clogged. quick question: when you say the radiator could be clogged, are you talking about internal clogging or on the outside inside the fins? I hope it's nothing major as I was planning on tracking my car this weekend. I also noticed whenever the radiator fan would kick on sometimes while idling, I could hear a slight squeaking sound coming from some where in the engine bay but only when the fan kicks on. Finally, running the heat or AC works for a while to keep the temp down while driving, but shortly after that, the temp would still rise slightly sometimes even at highway speeds. Any suggestions? I really want to track my car this weekend but I don't want to risk blowing a head gasket or causing other severe damage. This car is starting to annoy me because everytime I fix one thing, something else goes wrong. I have had coolant issues for a while and now I fix the leak and now it won't stop overheating.
also, today I saw what appeared to be residual coolant around the valve cover gasket. I am pulling the cover now to see if I see anything out of the ordinary...
