• Welcome to Mazdas247. Membership is free and offers many benefits, please Click Here to learn more, thanks!
  • Mazdas247 is an Amazon Associate and earns from qualifying purchases.
Broken outer door panel trim
Hi all. The lower plastic panel from the outer door skin was ripped off my car in a car park. The white plastic retaining clips are still stuck the metal of the door. I don’t want to damage anything can I safely remove and reuse them once attached back onto the plastic door panel?
Or do I need to replace the whole panel? With the lock down the Mazda dealers are closed.
Thanks gang
c
Toronto, ON Canada
2017 CX-5 GT
A new panel from the dealership will more than likely come with new clips already attached.
The plastic tabs are easy to remove with a plastic trim tool but probably better to leave them in place until you have your replacement trim piece.
2014 & 2019 CX-5 Touring(s)
From the look of them, you may well be able just to slide the new panel onto the existing clips.
2018 CX-5 Sport
I think they will break pulling them out and you will need new ones. It looks like they attach to the trim by inserting and turning 90 degrees.
How did it get pulled off? Did a chimpanzee want it?
Toronto, ON Canada
2017 CX-5 GT
It's way easier to apply the new panel with the clips attached to the new panel them snapping them into place on the vehicle. The clips do break but can be removed safely especially when it is warm.
Mazda is pretty good at providing the new panel with clips already installed with what I've seen before.
Pueblo county CO
CX-5 Sport 16.5 6M
I found some door panel clips at a parts store but they weren't white and they were meant for Toyota. I guess they are the same size. Auto parts stores stock quite a few sizes but they may not want to spend much time helping sort out which ones you need.
Any idea what the panel would cost? Or buy new clips?
As I said, you can probably reuse the clips and just slide on a new panel.
I know that my daughters Civic worked like that. I had to remove the plastic trim over the rocker panel at one point... there was a screw (or clip, maybe) that stopped the panel from sliding and that had to be undone, then you just jerked it sideways and the slots at the back of the panel slid off the clips.
From looking at your pic, I'd wager that's the exact same mechanism at play there.
Weekly Poll: Interested in the MX-30?
  • Yes
    Votes: 9 33.3%
  • No
    Votes: 6 22.2%
  • I want an Electric CX-3, 30, 5, 8 or 9
    Votes: 12 44.4%
  • I want an Electric Mazda2, 3, 6 or Miata
    Votes: 1 3.7%
Top
