@Vinipizz
Myself and others are often hesitent to simply recommend <Product name> for <what do I buy?> questions because we are not you. We don't know if you have a speficic terrain you drive your car in, we don't know if you pull a trailer, we don't know if you live your life a 1/4 mile at a time, we simply don't know enough to make a recommendation. Heck look at the dozen or so thread for floor mats and you can see even the most simply product garners strong opinions and emotions.
So as
@Buzzman12 has eluded to there are PLENTY of discussion about what people have picked and why. Maybe those use cases fit your use case, maybe not. But now you have some information as to what to look for and how to make a decision for YOU and YOUR vehicle.
Sometimes the search function of the forum can be daunting.. let me help you.
Hi guys, I am going to replace the brake pads (or attempt to) on my nephews 2016.5 CX-5 GT. I have done brakes pads before, but wanted to make sure there's nothing "special" involved in replacing pads on a CX-5? I purchased some OEM pads, and rotors. Thanks all!
www.mazdas247.com
2016.5 CX5. After 5 years finally time to replace brakes, rear. Dealership told me 2 brakes pads are there value and premium series. Can someone give the correct part # OEM for rear pads premium grade please? As my rotors look pretty “exhausted” too what would be the recommendation wrt rotors...
www.mazdas247.com
I was wondering what brake pads are owners using that they are pleased with. Low dusting, life etc.
www.mazdas247.com
The time has come to replace the brake pads. I'm going to replace the front and rear pads/rotors as I'm at 105k on the original brakes (we drive 30k/year). Usually I use Advance Auto parts for brake supplies but thought I would check out the forums. I quick search had some people recommending...
www.mazdas247.com
this was an interesting conversation on big brake conversion
Thinking of either converting something with brembos off skylines evos or similar to the CX-5 or Buying some 4POT Wilwoods with 330mm Rotors and having the brackets made up. Not too keen on the D2 / K sport / Yellow Speed kinda cheep stuff as I don't want any problems! Some of the Jap sites (...
www.mazdas247.com
are you trying to address brake fade?
I have seen a few "brake upgrade" threads for the CX-5, but none of them were focused on fade, which is the primary concern in my case. When we load up the 5 for extended camping trips, stock brakes are not able to handle long or repeating down-hills. Fade is pronounced and the steering wheel...
www.mazdas247.com
if you will be doing this replacement yourself (or maybe by a 3rd party) make sure you or they understand the electronic parking brake has a special method to get it IN and OUT of maintenance mode.
ok folks, I tried to make a video but it's too hard for this procedure, I needed to use both hands, so I'll write up a detailed procedure based on the Mazda PDF's provided by Anchorman (much thanks) see post # 12 of this link...
www.mazdas247.com
ok that should get you started.
