yes...if you are putting on more aggressive pads i suggest getting the dot5 fluid and flushing the complete system as more aggressive pads will create more heato.g.sk8er said:I will be putting on new power slotted rotors and new pads on Sat.
So I should bleed brakes right?
lxpony said:no need to bleed unless you disconnect the brake line from caliper guys.........................................
i took my stock p5 to the track a couple times (only had 2k miles on it) and the stock pads worked well for a couple laps before they started fading badly...heat em up and they don't work very wellwscottl said:More heat in the fluid? Maybe, but not worth changing your fluid unless you are doing track days or competition driving. Just changing the pads and rotors does not require a fluid change.
My stock P5 has been on the track and I had no problems with my brakes or fluid. If your car is used on the street or for autocross, the stock fluid will be fine.
Brake fluid traps moisture which lowers the boiling point of the fluid.
earlier this year, i changed to hawk hp+ and immediately boiled the stock brake fluid (just after doing a fresh flush of the systesm). I do lots of competition track driving especially with the turbo on the car
wscottl said:True, but it doesn't lower the boiling point to a level where it is unsafe. I have never heard of anyone replacing their brake fluid every two years on a street car. Of course, I'm assuming we're talking about street cars.
If this car is going to see any track time, I would hope the owner would know what he/she needs to put in there. I'm not saying it's not going to help on a street car, but every two years?
as most of us on this board probably drives a little faster than your average driver we will also be using the brakes more often and thus the more often and harder you compress the fluid the more it is prone to absorbtion of water or even creation of bubbleshttp://www.hondaautomotiveparts.com/maintain.htm
reason: Brake Fluid Replacement: Every 30,000 miles or 36 months
Why? Brake fluid is a hydroscopic fluid, which absorbs moisture and will lead to premature failure of various brake system components.
