Advice for replacing brake pads on 2017 M6T
L
Spring TX
V
2017 Mazda6
JMTXMaz6
Registered
Joined 9 days ago
Discussion Starter • #1 a moment ago
I have a 2017 Touring with 57,000 miles and I’m replacing the front brake pads & rotors this weekend. I’ve done brakes twice before on a Ford Expedition 2008, so I kind of know what to do. Rear pads still have 50% so I’m waiting.
I bought Centric C-Tek rotors and Posi Quiet Pro Pads from RockAuto.
A couple of questions:
Should I bleed the brake fluid & replace? Never done it but seems straightforward after reading stuff posted here & other forums.
If so do your recommend the gravity drain/ 2 person method or use a pump like the clerk at Advanced Auto showed me?
should I use anti seize on the back of the new rotor? Like Permatex
I am replacing the caliper pins and boots too. Is Permatex Ultra okay for lubricating them? It's readily available at Advanced
I will bed them after replacement per several posts I've read.
thanks for your feedback and any recommendations.
V
13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
57k miles yeah I'd bleed the brakes. I used this product and vid to do a 1-person job
I high recommend getting two products: Any cooper-based antisieze and any high temp silicone grease like Silaramic Brake Grease.
**Important** Only use High temp silicone grease for lubricating pins. Why? non-silicone lubs may not be compatible with the rubber boots and o-rings on the pins.
Copper Antiseize for backing of pads and tiny tiny bit on edges of pads where they slide unto the brake pad hardware (sliding clips).
Latest posts
Top
