AC compressor clutch replacement?
Hi there, I have a 2014 CX-5 Grand Touring. Does anyone know if it's possible to replace the clutch on the ac compressor without removing the whole compressor? I really don't want to have to pay to evacuate it the whole thing!
Thanks,
tim
Chris_Top_Her
Banned
Moderator
Contributor
San Antonio, Texas
'15 CX-5 Miata AWD
Thanks,
tim
You CAN buy a kit for it. It's like $40. I replaced mine last month. The assembly was jacked, but I was able to buy a used compressor unit for $78. I put it in the recycle bin otherwise I'd take a look for you. However I will say that the space around that pulley area is VERY limited as it's close to the frame.
2019 CX5 Reserve AWD
Thanks,
tim
You can do it on the CR-V so I'd be surprised if you couldn't on the CX-5. They probably use similar A/C systems.
Chris_Top_Her
Banned
Moderator
Contributor
San Antonio, Texas
'15 CX-5 Miata AWD
In case anyone else is interested, you can in fact replace the clutch on the compressor without (fully) removing it. The refrigerant lines going to it are fortunately flexible enough that I was able to unbolt the compressor from the engine and move it enough to get at the compressor. Just be careful you don't let the compressor hang by those hoses, obviously you don't want too much tension on those.
Top
