2013 Mazda CX5 Touring Wont Start
2013 Mazda CX-5 Touring
I own a 2013 Mazda CX-5 with close to 72,000 miles on it. I have tried to turn my car on, but to no avail. When I depress the brake pedal the start button lights up green so it is recognizing the key, but only turns the car to the on position where all of the electronics seem to be operating at a norm. The first 2 times that I try to turn the car on there seems to be a short crank, but then stops and after 3 times there is no cranking at all. Could this be a starter issue because I also tried attaching a battery to help jump start the car, but that did nothing either. Since the key is being recognized by the car and all of the electronics work such as the power windows, radio, lights, and locking the vehicle I suspect it is a faulty starter. Would anyone be able to give some insight to this issue?
Thank You!
CX5 GT +pp 2018
could be faulty starter, could also be the sensor in the break pedal. This comes to my mind at first glance.
shadonoz
SkyActiv Member
Contributor
State of Jefferson
2017 CX-5 GT AWD+
How old is the battery? Original? You could run a load test on it. Might have enough juice to wake up but not enough to crank.
mazdadude
ZOOOOOOOOOM ZOOOOOOOOOM
'16.5 Mazda CX-5 Touring
(friday)
what shadonoz said...
Starter is very unlikely. If your START/STOP light goes green when you press the brake pedal, that means brake switch is working.
Make certain transmission is in PARK while you are attempting to start.
If the PARK safety switch is faulty, it can prevent the car from starting too. You can try to press forward or down, or wiggle on the transmission lever while it is in PARK, all the while attempting to start by pressing the START/STOP button.
INSPECT BATTERY TERMINALS, and Load Test battery.
2019 CX-5 GT 184 2.2 twin turbodiesel auto - Sonic Silver
There was an issue with the inhibitor switch by the bottom of the gearstick.
madar
Contributor
2016.5 CX 5 Touring AWD, 2015 SCION XB
Check the battery first, regardless of the unsuccessful jump.
In the video I have given an update on the situation. I am waiting to get a battery tester to determine if this is the culprit to the issue. I am also in a bind because I live in NYC and had parked the car in a tight parking spot and am not sure how a tow truck would go about towing the vehicle to a shop if needed.
2013 CX-5 Touring FWD; 2013 BMW Z4 35i
You haven't answered the most important question. Is it the original battery? If so, don't wast your time testing the damn thing, just replace it. It probably wouldn't start with a jump because it's got a direct short in one or more of the cells. Six years is all you can expect from an OE battery. Yours has all the symptoms of battery failure. An yes, dash lights and accessories will often work with a bad battery, but there's not enough life left to provide adequate power to the starter.
ColoradoDriver
Gen-1 Kodo Design
Contributor
Denver, CO
2014 CX-5 Touring
Just replaced my 6 year old OE battery. It was definitely time. Can pick one up for $75 at Costco.
tibimakai
San Dimas CA
USA
2014 CX-5 Touring
6 years, that is a very long life, for an oem battery. My Costco battery, is already two years old and I'm only, at 48k miles.
CX5 GT +pp 2018
Assuming car battery is ok-ish. (Check this).
I see your button flashes amber.
This is from the manual doc. Two different procedures. The second is if the batt inside the key is low/dead.
(Forced engine starting method)
If the KEY warning light (red) illuminates,
or the push button start indicator light
(amber) flashes, this could indicate that the
engine may not start using the usual
starting method. Have your vehicle
inspected at an Authorized Mazda Dealer
as soon as possible. If this occurs, the
engine can be force-started. Press and hold
the push button start until the engine starts.
Other procedures necessary for starting the
engine such as having the key in the cabin,
and depressing the clutch pedal (manual
transaxle) or the brake pedal (automatic
transaxle) are required.
l When the engine is force-started, the KEY
warning light (red) remains illuminated and
(amber) remains flashing.
Note:
When the shift lever is in the neutral (N)
position, the KEY indicator light (green)
and the push button start indicator light
(green) do not illuminate.
If the engine cannot be started due to a
dead key battery, the engine can be started
using the following procedure:
1. Depress the brake pedal (automatic
transaxle) or fully depress the clutch
pedal (manual transaxle).
2.Verify that the push button start
indicator light (green) flashes.
3. Touch the push button start using the
backside of the key (as shown) while
(green) flashes.
4. After the push button start indicator
light (green) changes to full
illumination, press the push button start
with your finger.
- If there is a malfunction with the push
button start function, the push button start
indicator light (amber) flashes. In this case,
the engine may start, however, have the
vehicle checked at an Authorized Mazda
Dealer as soon as possible.
- If the push button start indicator light
(green) does not illuminate, perform the
operation from the beginning again. If it
does not illuminate, have the vehicle
checked at an Authorized Mazda Dealer.
Top
