2012+ Mazda5 How-To Master Sheet -=READ ME=-
Vasy
2012 Mazda 5
We need everyone’s help to keep things tidy. If you notice any threads that are NOT actual how-tos, please notify a mod to move it.
I shamelessly copied parts of the Silentnoise713's thread on pre 2012 models, hope it gives us good start.
There are many changes in 2012+ years so I though it would be a good idea to have a dedicated thread.
Many people post how-to but over time they get buried in history and searching for it becomes a PITA.
I hope you find this thread helpful and I'm looking forward to all the comments.
I'll try to do my best to keep the thread as up to date as I can.
Please note the following.
• Only post actual how-to guides in this sub-section.
• If you add a how-to topic, please send a PM to me or a mod to add the topic to this master sheet for easier reference.
• Topics are not listed in any particular order.
Accessories & Appearance(interior, exterior, roof rack, hitches, mechanical/physical add-on accessories)
• 2012 Weathertech digifits/OEM floor liner install
How to store rear cargo cover
• How-To. Mazda5 Smoked Taillights and Side Markers
Mazda5 OEM Roof Rack Installation Guide / Yakima Installation Guide
• Rear-view mirror -> Removal + Upgrade install instructions (Official Mazda)
How to add rear bumper guard
How to Install a spoiler in a 2012+ Mazda5 Sport
How to install hitch in 2012+ Mazda 5
How to add Running Lights To Mazda5 Sport
Integrated OEM turn signals
Removing the sliding door - in Pictures . This is for pre 2012 but steps should be similar.
Replace-Mazda5-Rear-Wiper-Blade - in Pictures.
Third-brake-Light-flasher - w/Delay module, Pictures. This is for pre 2012 but steps should be similar.
Replace-Mazda5-Rear-Wiper-Blade - in Video.
Engine, Transmission & Drivetrain(components directly/indirectly connected to the powertrain)
• Mazda5 turbocharger installation *cool*
How to change the windshield washer fluid reservoir (2012+)
How-To: Install Auxiliary AFT Cooler or in pictures. Another Write up here.
Front end squeak on '12 Starts at post #10
• How-To flush Transmission fluid / Transmission oil compatibility / Tranny fluid thread, there pre-2012 how-to, should be close to 2012.
• 2012+ Mazda 5 transmission oil change and addition of the transmission filter<br>
Car Audio & Electronics (all things electronic)
• Installing Blind Spot Monitoring System
How to change stock stereo unit
HID conversion And in pictures
Delay Circuit for Headlight Turn On
Light bulb comparison test, H11LL vs H9 vs LED (no HID at this time)
• Fog Light Instructions / Aftermarket running lights
• trailer light wiring
How to install rear camera for your DVD deck
Wired LCD Rear View Mirror Cam Install, another version
• Disabling Belt Reminder/Dinger Noise
Glovebox light install
Additional light in the cargo area
• How to remove tail light assembly to change bulb
How to add rear 12V outlet
How to add heated seats video another version with pictures
How to add underhood light to Mazda 5.
Adding a in-mirror turning light
How to install TPMS, tire pressure monitors, in a 2012-2013 Mazda 5
How to install rear screen in Mazda 5
How to Integrate a Wireless Charger in your 2012+
• Installing ScanGaugeE
• Horn upgrades
• Blower Motor replacement
• 3rd break light bulb replacement
• Mazda remote battery replacement
Rims, Tires, Brakes & Suspension (components that impact road dynamics)
• Front and Rear brake pads and rotors replacement - in Pictures. Just the front pad and rotors in Video
• The Rim and Tire Bible: http://www.carbibles.com/tyre_bible_pg2.html
• How to read rim markings: http://www.tyresizecalculator.com/wheel-markings
• Front Strut Replacement
• How-to Convert to MazdaSpeed3 FRONT disc brakes
• Rear upper arms with adjustable camber http://www.mazdas247.com/forum/show...-rear-camber-upper-arms&p=6413637#post6413637
Miscellaneous and Maintenance(everything else that doesn’t fall under Mazda247s standard listing)
Mazda5 Maintenance Manual
Mazda5 Owners Manual
Mazda 5 Online parts Diagrams 2012
• Celsius to Fahrenheit display switch
• Findway 3D Carpet Floor Liners
2012 Mazda5 Kids, Carseats & Safety Review
How to replace Air Filter
How-To replace the Cabin air filter
How to change oil and filter on a 2012+ MAZDA 5
• Frames' Mazda 5 Build/Maintenance Thread
• Dave88LX "follow-along" Mazda5 Suspension upgrade
http://www.mazdas247.com/forum/show...t-follow-along-quot-Mazda5-Suspension-upgrade
• Tomshardware.com Mazda 5 Project
• Sliding Door Lock Actuator Replacement - this is Gen 1, but could be similar on Gen 2, no confirmation yet.
• 2009 Mazda 5 blower motor diagnosis , but could be similar on Gen 2, no confirmation yet.
Thank you, Vasy. I keep telling myself one day I will be brave enough (and have the time) to do most of your electronic mods!
Awesome Vasy! Thanks for taking the time to do this and hyper links! I knew you were the perfect candidate :D
Here's a proposal. Would it be better to have two separate sheets or one sheet and mention next to each line item if it is applicable to Gen1 or Gen2 (technically Gen2 and Gen3 if considering the global model)? You guys can do as you wish.
Well, you made one thread for Gen1, this one for Gen 2 I'd say just to keep them as it is?
If we end up with a lot of overlapping topics it might be good to merge into one, but time will tell...
