2010 CX-9 backup camera not working
I have a sport model with backup view in rear view mirror. It hasn't worked since i bought it in the fall. Anyone have ideas of common problems? It's not something i really need, but wouldn't mind fixing if it's easy
2009 Mazda CX-9 GT
Is this even factory? Sounds like an aftermarket system. Either way, need to check the mirror and camera for power.
2010 CX-9 GT
Mazda offered a backup cam that displayed in the rearview mirror as an option.
I installed one of these on my car when it was new. This was a while ago, so the details are a little foggy. The kit came with a harness that runs from the mirror, over to the left a pillar, then behind the dash, then under the kick plates to the rear of the car. I'd check the plugs at the mirror itself and at the camera. The other thing to check is in the footwell - the harness taps into the car's electrical system there, where it picks up power and the reverse signal. As I recall the taps were pretty cheap looking so they may have come loose.
I had the same problem. I dissected the hell out of it. Found the problem was one of the wires in the lift gate going to the camera just before the camera cannon plug was completely corroded. There’s maybe 4 wires going into a sheathed bundle. I unwrapped that and found 1 of the wires was bare for some reason, it had no coating on it and it was pretty much powder after 10 years. The wire is coated going into the bundle just like all the other wires but inside it’s bare. That’s your problem. I spliced in a new wire and boom camera is working again. Hard to find but an easy fix. Bad design. Your welcome.
