• Welcome to Mazdas247, the 24/7 Mazda Community and Resource. Learn about the benefits of becoming a Member here.
  • We're an Amazon Associate and eBay Partner. We earn from qualifying purchases.
2003 Protege Constant Hum / Grinding Sound
salguod
Mr. T'bird
My daughter is 2003 Protege is making a humming or grinding sound that is dependent on road speed, not engine speed. Sound is constant in gear or in neutral, forward or reverse. Does not change when turning.
I put the car on jack stands and ran it in drive and reverse and the sound was still there. It was coming from the driver's side wheel but could have been behind. With the car in drive only the driver side wheel spun. With the car in neutral the passenger side wheel was harder to spin then the driver's side. Got under the car and examined CV joints and seal and found no obvious leaks and the joints and boots all look good.
No clicking on full lock turns like I'd expect with a bad CV joint.
Transmission fluid is full and the car drives and shifts fine.
LF wheel bearing replaced this summer.
I'm afraid that it's an internal transmission bearing. Thoughts?
I'm uploading a video to YouTube, I'll post it in a few minutes.
pcb
The Diagram Dude
2002 MP5
That sounds like a wheel bearing to me.
I know it was just replaced, but perhaps it wasn't installed or torqued properly or maybe just a cheap bearing?
The first time I did my bearings, the noise (or "roar") would come and go as I steered right and left but the next time I did my bearings, the roar was constant and didn't change with steering.
pcb
The Diagram Dude
2002 MP5
Just thinking...
What about trying a mechanics stethoscope to try to locate the source of the noise?
As long as you can get in there safely.
Top
