2002.5 Mazda Protege 5 Fully Built N.A.
2002.5 Mazda Protege 5 Mica Black,5 speed,Original Owner, No Rust, No Accidents,84,000 miles.Runs Strong.
Never Raced, Built as a Project.
- Fully tuneable Microtech LT 10s.standalone
- AEM wideband
- Autometer Oil Pressure Gauge
ENGINE:
- Integral Stg 2.5 cams
- Titanium valve retainers
- Stainless Supertech valve springs
- Cylinder Head Milled/Ported/Polished/3 angle Valve job
- adjustable camgears
- JDM 10.4:1 pistons
- 626 intake manifold (port matched)
- Maxbore Throttle body
- Deatschworks 440cc/min Injectors
- Unorthodox underdrive crank pulley
- AWR ceramic coated header
- AWR Engine Mounts
- AWR Oil Pan
- Magnaflow exhaust
(Much more not listed)
- Mishimoto radiator
- Spal fan
TRANSAXLE:
- Mazdaspeed Limited Slip
- Spec stage 2 clutch
- Fidanza 7lb flywheel
SUSPENSION:
- Tokico hp struts
- Eibach Pro Kit springs
- Progress 22mm rear swaybar
- Front/Rear GT Spec Strut Tower Braces
- urethane control arm/tie rod bushings
BRAKES:
- Stoptech slotted/drilled rotors front.
- Stoptech rear rotors.
- Hawk pads
- Goodridge stainless brake lines.
WHEELS/TIRES:
- Rota Grid (black) 17/8
- Falken FK 452. 215/35/17s
Much Much more not listed.
List Date: 6/10/2014
Location: Newport, Berlin Charter Township, MI, United States
For more info, click here to view the original listing: 2002.5 Mazda Protege 5 Fully Built N.A.
This item is no longer available.
- AEM wideband
ENGINE:
- AWR Engine Mounts
- AWR Oil Pan
- Magnaflow exhaust
- Spal fan
TRANSAXLE:
SUSPENSION:
- Tokico hp struts
BRAKES:
- Hawk pads
WHEELS/TIRES:
