- 2014 Mazda3 S GT auto, 2008 MX5 6-speed
Okay, it was the first oil change, so keep that in mind. Here are some of the highlights:
1. When you're rolling with Eibach springs, forget about using your Rhino ramps. I then broke out my custom low profile wooden ramps, just to get the car up high enough to use a floor jack. But wait, there's nowhere to jack up the front-center! Okay, time to try out the scissors jack in the trunk......waaaaay too slow. Hmmm, maybe it would be best to pay the dealership to do it? Nah, deep in my barn is an old set of steel ramps and an "extension kit" for lowered cars.....perfect! The tires are just narrow enough to fit.
2. The underside is almost entirely covered by plastic panels, you know, for aerodynamics. A small sub panel on the passenger side is removed by popping out the plastic pin's center with a flat blade screw driver. I think there was a screw or two to remove.
3. The oil filter and drain plug are directly behind the panel - nice! Unfortunately, the oil filter is so small, none of my filter wrenches fit. The replacement filter, a K&N with welded-on nut will be alot easier to remove during the next oil change. At this point though, I realm don't want to go out and buy yet another filter wrench so it was hammer time.....actually, screwdriver and hammer time. I pounded a deep hole in the OEM filter and used the screwdriver as a torque lever.
4. The drain plug has an internal hex socket hole. An 8mm L Key wrench with box end wrench ( to add leverage/more torque) got the plug loose to drain that 4.8 quarts of 0W-20 oil.
5. While the oil was draining I spritzed the engine bay with water and wiped it off with a paper towel. I was surprised at how dirty the towel was after only 9 months or so. Part of my cleaning/observing routine is the check the water level in each battery cell. The threaded and elastomer-sealed cell caps are unique in that they double as a sort of dip stick to verify whether the water/acid level is adequate. The shape is interesting - a sloped step of sorts - very innovative. The battery has "High Performance" and "Stop/Start rated" or something to that effect.
6. The oil fill cap is right next to the dipstick. The plastic cover does not need to be removed.
7. By the time I cleaned up, 2 hours had passed,
but I can guarantee you the the next change will take less time.
8. I set the reminder to be based upon an oil life algorithm instead of mileage. I did follow the manual's method of resetting the maintenance wrench symbol by holding the trip button and setting ignition to ON. However, the wrench symbol did NOT turn off. Anyone know what may be the issue with that? Update: See my other post about the wrench light. There are 3 different reminders that can trigger the light. All are reset by using the infotainment screen.
