1989 Black RX7 Turbo II Swap Project - $3500obo - GA
Status
Not open for further replies.
Keno1542
Yellow Jacket
V
Mazda MP3
The good:
Clean Body - No Rust. Turbo II full swap including transmission, driveshaft, differential, and professionally rebuilt axles. Godspeed FMIC kit, Apexi intake, RTek chipped ECU eliminates fuel cut and OMP, also retards timing one degree for every psi of boost over stock. CyberStork white face JDM Turbo II cluster, Grant steering wheel and hub, Walbro 255 fuel pump, D2 coilovers. New Rear Wheel Bearings. Fresh Redline Fluids in Transmission and Rear Differential. Solid Delrin Differential Mounts Installed. Turbo has been ported to avoid boost creep. New Aluminium Radiator - Ebay. New Stainless Turbo Back Exhaust - Ebay. New Wagner Brakepads all around. Dual Belt alternator pulley and new belts - need to be installed. New Radiator Hoses.
The bad:
Not currently running. I bought this as a project, but have had some health issues come up and hope to find someone else to finish this project. All in all it is about 85 - 90% complete. Car comes with everything needed to finish the swap. Wheels are mismatched - temporaries to roll the car around. Clearcoat Peeling.
Things left to do:
Finish installing FMIC kit along with a few other things under the hood, install the front bumper, install the exhaust, drain fuel tank(fuel is a couple years old), new oil and filter, new spark plugs, battery relocate due to the FMIC, minor assembly of the interior, and finish window switch fix.
As you can see the car is pretty dirty, but overall the interior is in pretty decent shape. The exterior needs paint(clearcoat is peeling), and there are a few dents and dings but nothing major.
$3500 OBO. Willing to trade for a running car with cash on either side depending on the car.
Status
Latest threads
Latest resources
Top
