'18 CX-9 and Fortin Remote Car Starter...Success!
CX-9
Ok folks, if I figured it out, you can too. I absolutely refused to spend the $500 Mazda and other installers were looking for to install a system on my behalf.
Based on a lot of research, and conversations both with the manufacturer (Fortin) and retailer (Crutchfield) I picked up the following components:
Fortin EVO-ONE with MAZ3 harness:
https://www.crutchfield.com/p_938EV1MAZ3/Fortin-EVO-ONE-MAZ3.html?tp=77914&omnews=14762862
Fortin Flash Link Updater:
https://www.crutchfield.com/p_938FLU1002/Fortin-FLU-100-2.html?tp=155&omnews=14762862
Total was around $230 as Crutchfield takes a discount if you buy both.
Install was easy - if I can do it you, you can too.
A couple of things that I learned:
1. The order of operations aren't 100% clear from the directions, so do this:
1. Disconnect (-) terminal on battery
2. Open the steering column and install the harness to the car (NOT the module) per the instructions. It's really just plug and play.
3. Reconnect the battery
4. Update the EVO-ONE module per the instructions below.
5. Connect the EVO-ONE module per instructions
6. Run decrypter process and test​
2. The EVO-ONE module probably needs to be updated before you try and install it in the car. Mine was not up to date and was not working with the included instructions. I called Fortin to troubleshoot and they walked me through updating the module and the final install/tests steps on the car. If I had known what the problem was, I probably could have resolved in on my own, but it's probably worth a call. If someone does call, take notes and publish here. If I had known how straightforward it was going to be, I would have done so.
3. Don't forget to cut the yellow loop.
AreDee
Contributor
2016 CX-9 Grand Touring Sonic Silver 2017 CX-5 GT Eternal Blue
This sounds intriguing and I'm interested, but would this invalidate any warranty coverage provided by Mazda?
'14.5 CX-5 Touring AWD, Soul Red | '14 CX-5 Touring AWD White
I put fortin on my CX-5. It was about $150 total for module, harness and programmer. I got all from Crutchfield as well.
2017 Crystal Mica Blue GT CX9
Does it shut off the engine when you open the door or did you implement some sort of bypass for this?
CX-9
Nope. Comes with that already fixed.
Works just like any other car starter I've ever used. When you get in the car, press the start button once and off you go.
Only issues I've found so far is that the one touch up/down on the car windows doesn't appear to be working... I haven't had enough time to troubleshoot yet.
Best Buy quoted me $425 for a super basic install and told me I was going to have to wait 3 months. Local car audio installers were quoting me north of $500.
Easy peasy.
Easy peasy.
Nice! I may have to look into this. Do you get a separate keyfob with this setup or somehow integrate the Mazda stock remote start unit?
CX-9
What Audifile say above....
I'm 90% positive that it works with both of my keys too, so that's more money saved over a different system.
Do it.
The customer support from Crutchfield and Fortin make it a no-brainer.
AreDee
Contributor
Easy peasy.
Were you able to get the one touch up/down windows working?
CX-9
Honestly, haven't really tried yet.
The majority of the time that I'll be using it is during the winter, so I don't really care about the windows.
Additionally, I almost always end up hitting the brake to start it normally and kill the auto start. In other words, more often than not, I end up starting it normally right before I start driving.
2018 CX-9 GT AWD
MattGoose, whenever you disconnect the battery the safety mechanism causes the one touch windows to no longer function. It's similar to if you get something caught in the window going up (eg. a child).
To reset it (has to be done for all 4 windows), just roll down the window all the way by pressing down the switch keep it depressed for an extra second, then roll it all the way back up and keep pulling up on the switch once it's up for an extra second. Then when you've released it you should be able to auto open/close again.
+1 on the Fortin did that a few months ago and it's great!
CX-9
Thank you thank you thank you!!!!!
I was really confused because I couldn't figure the pattern out on this. My driver window was working again, but none of the others. I must have accidentally reset it.
The Fortin is a great addition and I'm still very happy with it.
2016 Mazda CX-9 Grand Touring AWD
when activating the fortin remote start, does the engine shut off when the driver side door is opened, or any doors for that matter?
CX-9
Nope.
Stays started when you open the doors or the lift gate.
When you get in the car, you have to hit the start button, otherwise when you hit the brake to put in gear it shuts off.
The only thing that stops the car is a 15 min timer or if you hit the brake.
Also confirming that my windows are now working. Disconnecting the battery also reset some of the other settings in the car, but it appears to be random. My stereo, for example, the bass/treble settings remained the same but I had to go back in and select the Bose AudioPilot and Centerwhatever options.
