I am highly suspicious of criminal vandalism as the cause of this but:
One of my two belts completely shredded, almost completely knocking the other one off, and I am obviously going to have to get it fixed, and can't/won't be able to spend the money to have a shop do it.
How easy is this to do? Special tools?
What are the names of the belts for locating a replacement?
How much might it run me in parts cost?
Damage in detail:
I am going to refer to them as the inner and outter belts. The inner belt is physically closer to the engine block than the outter belt. The inner belt runs between 2 (i think) pulleys, the rear pulley looks to be the alternator. The outter belt runs between three pulleys.
The inner belt is completely off the pulleys, and I can see the shredded pieces of it it laying in the back of the splash-pan. The outter belt has 'jumped' over on the pulley grooves, only hold on with 2 out of 5 grooves. The belt is still incredibly taunt, and shows no sign of damage, cracks, or wear. I had loaned the car out to my mother-in-law and sister-in-law for 2 days, and neither of them could tell me of any strange noise etc... I realized the problem as I was leaving home, and saw the battery light was on. A short distance after that I noticed that the temp gauge needle was ABOVE the highest mark on the temp gauge. I pulled into a parking lot to find out what was going on, and discovered, first, that the coolant hose that comes out of the top of the radiator just under the cap was off and the hose clamp was missing, coolant spewed all over the engine bay. I hooked it back up and put a new clamp on, and let the car cool down while I tried to figure out what happened. Then I noticed the one belt had shifted, and then that the other was missing. Seems that the coolant pump is something that was driven by the missing belt, though I have nothing to back that up other than the fact that the engine is overheating like crazy and won't cool down.
Questions for more detail are welcome, and any help is deeply appreciated.
Damage in detail:
