As promised. Its dusty and front fan filters definitely need cleaning.
New phone so I am figuring out this camera. Color doesn't look right on the fan controller in the second pic. They are yellow.
Also, the plastic insert inside the CPU waterblock has discolored to a white color over the past 4 years. Will have to replace that at some point.
Components:
CPU: i7-4790k
GPU: ASUS GTX 980 Strix
MOBO: ASUS Z97 DELUXE
RAM: Corsair 16GB DDR3
SSD: Crucial M550 512GB
HDD: 2 x WD Black 3TB
PSU: Corsair AX750
Case: Corsair 540
Fan Controller: Lamptron FC5v2
Cooling:
Fans: 6 x Corsair SP120's - white rings painted gold (Would have used my Gentle Typhoon AP-15 fans if they wouldn't have ruined the look of this build)
CPU: EK Supremacy EVO - Gold
GPU: EK Fullcover + backplate
Pump: D5 Variable pump (lowest setting for silence, these thing move a lot of water)
Reservoir: EK X-RES 100
Tubing: Primochill Advance LRT - Black (3/8"ID, 5/8"OD)
Fittings: Monsoon compression fittings - Gold (3/8"ID, 5/8"OD)
Rads: 2 x XSPC EX240 (I couldn't quite make my EX360 fit up front with both hard drives)
Regarding the fans...it was a compromise. Gentle Typhoon fans are simply the best that you could get for radiator fans water cooling because they move a ton of air, have great static pressure (important for radiators), and most importantly are just quiet. One of the other major reasons I got into watercooling is that I like silent computing. I don't ever want to "hear" my computer. I can run all my fans very low and get better cooling than air cooling without the fans spinning up to insane levels gaming. I can adjust manually as needed with the fan controller.
