- 1989 RX-7 GXL Blaze Red
yes i heard, mine should arrive soon.. hopefully
I checked tracking but the last update was in Chi town. Hopefully they aren't stuck in customs lol
nice! I need to find me a 1.8l coil conversion now
when i checked it said the same thing, but i also have updates on Cdn post so hoping they passed through.
So, quick story. A few months after owning the p5 a man merged into me and crumpled my rear fender on the passenger side. I paid big (insurance) money on body and paint, plus I threw in stone poof my own money for more work and in the front. It's apparent a few years down the road that I got bad body work and bad paint. The paint started chipping and now today I realize the fender work they did is what is causing my fender rubbing. Instead of fixing it back right, that didn't raise the body out as far as it should have been, used cheap filler, welded in thick metal and used cheap paint. I can't simply roll the body out enough to fix Terr issue because everything would simply break. Instead of paying the thousand dollar rough estimate to repair everything, I think I'm going to pay $25 for camber bolts and put just enough camber on the rear to tuck under the fender.
I don't have a build thread cause I'll a slow modder with bad luck lolI had to do a double take on who's build thread I was reading...
You will need longer studs if you plan to run those spacers....
Looking good man!
He is planning on it. But there are plenty of people running 8mm spacers on stock studs without problems. I can't argue with piece of mind though.
Did you already swap the studs, JT? I'm hoping I can swap out my studs with the hubs still mounted on the car. Just put a used lug nut on the stud and pound them out, then pull the new one in with another lug and the impact wrench.
I've only got the 5mm spacers but maybe my wheels have more material so less threads. Better safe than sorry.
got past customs...yay!
big sigh of relief there!
