i did the math and this will cost much less.
cams 360 for both
pistons 196
then whatever i add...
ideally, rings sure. but unless your compression is going, its not a pressing concern. no need to replace bearings unless yours are gone or you're ripping the block apart.id need new bearings and rings with a turbo too....
except that i have 147xxx miles on it
im going to go na because everyone goes turbo and i want to be unique.
Haha, always throwin out this "unique" word...
yep. well in a world of tuned hondas i guess we are all unique there... but its just nice to not follow trends.
on a relivant side note . my valve seals are completely gone. so im going to be taking my head off and doing everything that needs to be done while its off. my plans for the car are to run a stock MSP turbo and stock boost eventually and a goal of 200whp. Is it worth putting in the JDM intake and exhaust cams too. or can that somehow screw with the turbo for the increased duration on the cams?
No, it won't hurt the turbo. They will yield you decent gains with the stock MSP turbo setup, too. Maybe ~8whp. If you tune, anyways...
15 hp but it would be about 7 at the wheels
well porting and polishing isnt gonna do much to these engines until they are tuned for it... you already have the ecu, so just get pullies, and cams and be done. the difference is really in the power to weight ratio. it may not seem like much but 10 horsepower really made my car pick up! only get things you can still use when you get boost so you dont waste money
