Jdizzle659
- Mazdaspeed 3
What upgrades would you recommend besides tires and mounts for getting better traction in 1st and 2nd gear?
burnouts before you race, to leave a fresh layer of sticky rubber. chewing lots of gum and sticking them on your tires. coarse grit sandpaper on your tires.
seriously, the only way you're gonna get better traction in 1st and 2nd (assuming you are just talking about launches/racing) is if you get wider rubber, or just keep your foot off the ground
launch in reverse
Traction has a lot to do with the driver but after a TRZ MM and Eibach springs I no longer get crazy wheel hop and get somewhat better traction, that paired with some wider tires would help some but traction will always be a problem in this car.
I have issues with traction coming out of corners.
But traction from a dead stop is all the drivers fault. Control the Revs and slip the clutch, I have no issues with moving forward and have Zero Wheel hop.
launch in reverse
wouldnt you consider traction out of corners to also be the drivers fault? too much gas to soon after the apex. gunning it instead of rolling it on?
