The AWD technology of Saab XWD
mikeyb
Contributor
01 BMW 325xi Touring
Saab XWD Cross Wheel Drive is a system designed to optimize the vehicles handling and stability in all driving conditions. Cross Wheel Drive represents a state-of-the-art drive system which includes two innovative features: pre-emptive engagement of the rear wheels to optimize traction at take-off; and an active rear limited-slip differential, allowing variable torque transfer between the rear wheels.
Developed in Sweden with Haldex of Stockholm, the Saab XWD Cross Wheel Drive system is designed to optimize vehicle handling and stability in all driving conditions. It is offered in the 2008 Saab Turbo X and Aero versions of the 9-3 Sport Sedan and SportCombi, in combination with an uprated 280 hp (206 kW), 2.8 V6 turbo engine which now delivers almost 15% more maximum torque (400 Nm/295 lbs/ft) to exploit the greater traction available.It comes with a choice of six-speed manual or automatic transmissions.
This state-of-the-art all-wheel drive system includes two innovative features: pre-emptive engagement of the rear wheels to optimize traction at take-off; and an active rear limited-slip differential (eLSD), allowing variable torque transfer between the rear wheels.
Saab XWD is a fully automatic, on-demand system capable of sending up to 100% of engine torque to the front or rear wheels whenever necessary. While offering new Saab Turbo X and 9-3 Aero XWD owners sure-footed handling in low-grip conditions, its sophisticated operation also adds a further sporty dimension to the driving experience in all road conditions. Fine balancing of the drive torque between the front and rear axles raises the threshold at which ESP throttle and braking interventions are triggered, providing more scope for closer driver involvement.
The system is governed by its own electronic control unit, which functions in harness with the engine, transmission and ABS/ESP control modules. The hardware consists of a Power Take-off Unit (PTU) in the front final-drive that transmits engine torque through a prop-shaft to the Rear Drive Module (RDM). This incorporates a Torque Transfer Device (TTD) and an electronically-controlled Limited Slip Differential (eLSD). Both are wet, multi-plate clutch units from Haldex.
At take-off from rest, the TTD is initially activated when the clutch plates are forced together under hydraulic pressure, thereby engaging the RDM. This pre-emptive function is a valuable improvement in current technology, which requires the detection of wheel slip before the TTD is activated. For the driver, the enhanced functionality gives maximum traction immediately for smooth, strong acceleration from rest without the possibility of any initial hesitation.
On the open road, drive torque is seamlessly and continuously varied between the axles by the control of a valve in the TTD, which increases or reduces the pressure on the wet clutch plates. When cornering, Saab XWD rewards the driver by providing enhanced, more finely balanced chassis dynamics. Data from the vehicles ABS/ESP sensors - measuring wheel speed, yaw rate and steering angle is utilized, and careful programming of Saab XWD enables the application of rear drive to balance oversteer and understeer characteristics, improving stability and roadholding.
In highway cruising conditions, when traction or optimum grip is not an issue, only 5% to 10% of engine torque is typically transmitted to the rear wheels. This helps provide the driver with a measure of greater stability, while helping to save fuel.
The ultimate icing on the cake with Saab XWD is the eLSD. This is the first application of an electronically-controlled, rear limited slip differential in this segment of the market. The eLSD is installed alongside the RDM and operates via pressurized clutch plates on a principle similar to the larger TTD. In icy or wet split-friction conditions, for example, it uses inputs from the rear wheel speed sensors and can transfer up to 40% of torque between the drive shafts, to whichever wheel has more grip.
The eLSD also gives the driver enhanced control when cornering hard or completing a high speed maneuver, such as a lane change, by momentarily applying more or less torque to either of the wheels to help the rear of the car more closely follow the direction of the front wheels. This yaw damping effect can keep the car better balanced and more tightly controlled, without requiring outside intervention from electronic stability aides.
Installation of Saab XWD includes the fitment of a new rear sub-frame to carry the RDM, revised rear suspension geometry and new wheel hubs for the drive shafts. The three piece prop-shaft runs through two bearings with constant velocity joints for smooth running with minimal wind-up. Wheelbase and rear track dimensions are unaltered. All Saab Turbo X and 9-3 Aero XWD Sport Sedan and SportCombi models will have 18-inch alloy wheels as standard equipment.
Hot. Saab needs some love, but I don't think they're going to get it. This may or may not convince some of the hardcore Saab enthusiasts to come back, but I don't see it winning over any buyers from other luxury brands.
I think Saab needs alot of Love. It seems GM is trying to give it some but it needs alot more then they are giving. Saab needs to expand its model range and replace the old 9-5 with a all new car and come out a small car to replace the Saabaru 9-2x. Also add a coupe of the 9-3 that model line and add a halo car in the spirit of the Sonett.
Forget SUVs or CUVs leave that to other General's brands to deal with that market segments.
Saab is depressing lately.
I miss them being the quirky swedish car company that churned out fun turbocharged cars.
I'd dig a new Sonnet if they came out with it.
AWD 6-speed manual SportCombi? SWEEEEEET.
we traded my fiance's '99 9-3 on our CX-7 (we considered a SportCombi), and that car was one problem after another, but damn it was a good car when it worked. even w/ the base 185hp motor, that thing could haul.
saab needs to do a better job with reliability (although i'm sure a new one is better than our high-mileage model), and in tightening up the diver interfaces. in that car, everything was a little sloppy...steering, shifter, pedal movement. but then again, it was significantly quicker than the CX-7, got 30-32mpg on the highway, and fit just a little bit less stuff.
I will admit, despite my current displeasure with Saab, the sportcombi is pretty damned cool.
No, but I think I'd like to, despite it being wrong-wheel-drive.
I would think Saab would sell a XWD 9-3 2.8T to compete with the A4, C 350 4matic, S40/V50/S60, 325xi/335xi, and Subaru Legacy GT.
edit: The XWD will be used with the 2.8T. Man my brain is fried.
Developed in Sweden with Haldex of Stockholm, the Saab XWD “Cross Wheel Drive” system is designed to optimize vehicle handling and stability in all driving conditions. It is offered in the 2008 Saab Turbo X and Aero versions of the 9-3 Sport Sedan and SportCombi, in combination with an uprated 280 hp (206 kW), 2.8 V6 turbo engine which now delivers almost 15% more maximum torque (400 Nm/295 lbs/ft) to exploit the greater traction available.It comes with a choice of six-speed manual or automatic transmissions.
Have any of you driven a 9-3 2.8T?
I drove one at a GM SAE event earlier this year, and took it on an autocross course. Horrible understeer, but provided decent power. You really had to watch though because it handled like a bag of poo.
Well, I'm use to dealing with horrible understeer and handling like a bag of poo. Remember I drive a VQ35de powered Altima.
Latest posts
