- Completely Stock P5
$125 first hr
$75/hr each hour afterwards here
USD vs. CAD
$125 first hr
Again $600 is WAY too much you are getting ripped off, especially if it's a Speed6.
If it takes more then 2 hours then that person is an incompetent fool.
Mine was done on a Dynapack, in just over an hour. And this was the first time the tuner (Shawn Church) ever seen the CP-E tuner, let alone tune a Speed6.
In any case, if you don't want to be part of the group and share, that's fine. But don't make up BS excuses.
Yeah, but the original poster is asking for a tune for a standback, tha'ts not a standalone.
If there is a standalone for the SPeed.....I want one.
Dyno tuning all the load points and having ample cool down between runs is about 2 hours. I still see 2 hours dyno time being reasonable.
Dyno rental/tuning rates are different at each location so it maybe cheaper in one area.
Standback is just the product name CPE came up with.
Piggyback is an interceptor that modifies the signals.
Standalone is a programmable ECU independent of the factory ECU.
Thanks! So wouldn't a standalone in theory be able to get around the throttle plate issue on the ms6 and ms3?
What throttle plate issue?
