Just wondering, since you have a new transmission can this no start have anything to do with the start in Park switch?
I'll check the fusible link and will ask about the start in park switch at the dealer tomorrow. I will let you all know what they say. I did see the fusible link when I changed the battery. It looked fine to me, but then again I really don't know what I am looking at. Everything appeared to be properly connected and clean in and around the battery.
I'm concerned about the lack of fluidity of the tranny when decelerating. During slow deceleraton at slower speeds, the transmission seems to log the engine because of hanging on a higher gear.
For the curious, the service advisor says that the connection to the starter terminal is loose and that they are going to have to replace it. Since Mazda is closed today, I am back with a rental vehicle through Thursday. My Mazda 5 has been out of service since Dec. 18, over two weeks by the time I get it back. I am now eyeing the Ford C-Max and Prius V as potential replacement vehicles if I have too many further problems, as I need a car that is reliable. We will see...
No start due to a loose terminal on the starter = human error. Not really an issue with the quality/reliability of the Mazda.
On the other hand, I can understand your frustration in the entire situation.
So I get a car from the dealer: good news, your car is fixed! The shuttle driver brings out the car (only about 3 miles from the dealer) to fetch back the rental. Shuttle driver gets here and unknowingly parks behind my rental. I get in my car to move it out of the way and...it still doesn't start!
Shuttle driver calls dealer, the tech asks if it starts in neutral...it does start in neutral. Whatever repair was attempted on the loose terminal failed. The 5 goes back to the dealer again, and I still have the rental. The saga continues...
HOLY CRAP! Find a new dealer!!
Yup!! It's not Mazda reliability it's dealer lack of competence.
I agree with you. I wish there was another dealer close to me. Next closest dealer is in another state, 75 miles away. I will think twice before taking my vehicle back to these guys. I will say that Mazda has stood behind the warranty completely. I'm only out for $100 for the battery that I changed on my own thus far.
Are you very close to Louisville?
I'm own a Mazda Premacy 2.0 2004. My transmission warning light "HOLD" keep blinking when drive it. It seems like the sensor in the transmission is fault. When the light is blinking, the transmission is very rough likes the gear shifting too fast. Any member here have found the same problem like this or anyone can give me any suggestion or solution ? Thanks
