The CX9 turbo engine has been around long enough to determine if the MAZDA idea of running the valve hotter is working to keep the valve clean. Has anyone taken a look at the valves or had them cleaned by any method on engines with 50,000 miles and more?
The carbon comes from oil vapor from the positive crankcase ventilation (PCV) system venting crankcase vapors into the intake manifold. The oil vapor hits the backside of hot intake valves which are not washed by gasoline vapors (due to the direct injection of gas into the cylinders) and the oil vapor bakes to carbon.
Several on this forum have installed oil catch cans to collect the PVC oil before it gets to the intake manifold. All the reports I've seen show that there is no oil for the catch cans to collect. The catch system built into the engine must be doing a very good job. Also, I haven't seen any reports of carbon build up causing engine problems as sm1ke writes.
Part of the benefit of the current oil category, ILSAC GF-6A, is, "Introduced in May 2020, designed to provide protection against low-speed pre-ignition (LSPI), timing chain wear protection, improved high temperature deposit protection for pistons and turbochargers, more stringent sludge and varnish control, improved fuel economy, enhanced emission control system protection and protection of engines operating on ethanol-containing fuels up to E85." (Emphasis mine)
https://www.api.org/products-and-se...categories-and-classifications/oil-categories
In case the symptoms sm1ke describes do occur there are ways to clean the intake valves, either chemical cleaning (here is one example: https://www.bgprod.com/services/gasoline-fuel-services/gdi-fuelair-induction/ ) or kinetic cleaning where the head is removed and disassembled and the valves blasted with walnut shell abrasive.
This is not really accurate. While some better-quality catch cans may slow down and capture some of the oil vapor there is still oil vapor that goes into the intake and will cause carbon to form on the intake valves and piston tops and cylinder head chambers. I am sure if you check with independent service shops, they can inform you how many DI engines each month they recommend a carbon cleaning. Mazda has no special means as of date to prevent that carbon from forming.
I would say for the more DIY you can pull your Throttle body and shine a flash light in the intake runners and I am sure you will sill a slight oil film on the intake walls.
Now I am not suggesting that you all be worried only don't think it does not happen. As for not feeling or seeing a drop off of power or MPG, it so gradual that the time the carbon is bad that's when most will start thread asking why both have increased. For some that claim no difference after 40k miles if you are really curious have your engine analyzed on an oscilloscopes and have the Technician look closely at the ignition data. Or just have the intake manifold and combustion chambered scoped!
Yes good eye. I was reading the resent responses and simply responded not paying attention to the quote captured. It can still hold value even without the quote from any member, I should think?I think you may have quoted the wrong post. This sounds like it was in response to @PTguy's post.
