Hi everyone, I've just installed my new MSP in my protege 5
a big probleme we have right now is with my Split second AFC & timming control
engine between 3500-4000 rpm cuts out like a .......
2 weeks ago I went dyno tuning to fix the probleme, did the session, no more cutting (25deg celcius), and on my way back home(650km away) colder it got, a cutting out started to appear, now every day just puttering aroud 3500-4000rpm is not even possible. When its really cold, 5-10deg celcius, aroud 6200rpm it cuts once or twice. The guys at the dyno shop had no idea how to tune my split second, so I think thats probably the only reason why its not working properly
here are my mods, if it helps
-GARRETT T25 Ball-Bearing Turbocharger
-Callaway Manifold
-CORKSPORT Front mount intercooler
-GREDDY TYPE RS blow off valve
-AEM cold air intake
-COLD TIP plugs
-AFC SPLIT SECOND Air fuel and Timing Controller
-APEXI turbo timer
-Stock speed exhaust
-TOCHIGI FUJI Limited slip differential
-GREDDY oil catch tank
-GREDDY profecB spec boost controller
-ARIAS PISTONS
-PAUTER rods
-ARP head stud kit
-AEM Wideband
-EXEDY clutch stage 2
-AWR kit motor mount durometer 88 stiff
and a little sample
http://www.youtube.com/watch?v=S7x5yuLvK7U&feature=channel_page
Getting kind of fed up(hand), so if anyone knows WTF is the probleme, it would be greatly appriciated(thumb)
-Callaway Manifold
-COLD TIP plugs
-APEXI turbo timer
-ARIAS PISTONS
-PAUTER rods
-ARP head stud kit
-AEM Wideband
and a little sample
