so inother wors, install them to the torque that is recomended by Mazda.Listed are the recommended torque values for most ARP fasteners. Recommended torque is equal to 75% of the fastener's yield strength. THE TORQUE VALUES REPRESENTED HERE ARE INTENDED TO BE FOR GENERAL INFORMATION, NOT FOR SPECIFIC INSTALLATIONS! In special instances, where supplied instructions deviate from the torque values recommended here, always follw the intructions.
Right. But if that's the case, then for a 5/8" stud, it can take as much as 303 ft/lbs to properly torque. That's total BS...that's what scares me here.RyanJayG said:quoted from the top of the page
the stock bolts are torque to yield for a reason. set these as if you were instazlling a new set of OEM head bolts.
well, what you have to realise is that those ratings are just 75% of yieldKooldino said:Right. But if that's the case, then for a 5/8" stud, it can take as much as 303 ft/lbs to properly torque. That's total BS...that's what scares me here.
