Mazdas247.com Mazda Competition & Factory Parts @ Racer net pricing! Go Tri-Point!
Go Back   Mazdas247.com > Community > Automotive News, Articles & Pics
Notices
Reply
Thread Tools Display Modes
Old 11-13-2003, 07:23 AM   #1
mikeyb
Registered User
mikeyb's Avatar
Donated: $20
Automotive News Moderator
01 BMW 325xi Touring
Ultimate Sport Compact Car?
As usual I'm browsing of www.autoweek.com and was looking at the SEMA Show pics and found this.
http://www.autoweek.com/specials/200...s8/pages/1.htm
A Focus with a V8. Is this the Ultimate Sport Compact Car?
__________________
____________
2001 BMW 325xi Touring with Premuim Package
2003 Nissan Altima 3.5 SE (For Sale)
2006 Ford Focus ZX3 SES
Near Future 2011 Brammo Empulse and Mini Cooper S
(OO=[][]=OO)
mikeyb is offline   Reply With Quote
Old 11-16-2003, 12:40 PM   #2
jred321
Registered User
jred321's Avatar
wranglher
if you want to go in a straight line, maybe
jred321 is offline   Reply With Quote
Old 11-16-2003, 12:41 PM   #3
xelderx
Zoom Zoom Boom X 3
xelderx's Avatar
Saw it at NOPI...not all that impressive. The rear suspension looked like it came off my riding lawnmower.
__________________
xelderx is offline   Reply With Quote
Old 11-16-2003, 12:53 PM   #4
MarkSpark
Touche
MarkSpark's Avatar
Donated: 5$
Protegé ES
I'd buy it. Put in an aftermarket suspension kit and wham! First they need to change the design.
Focus RS8
Ford Racing Performance Parts (FRPP) used a sport-compact car to display the company's latest addition to an already powerful crate engine line-up – a modified Focus RS converted to rear-wheel drive and V-8 power – with the introduction of the Focus RS8 at this year's Specialty Equipment Market Association (SEMA) show.
Using the European Focus RS as a starting point, FRPP worked its engineering magic to mate its new, all-alloy, 5.0-liter 4-valve "Cammer" crate engine – cranking out a pavement-pounding 420 naturally aspirated horsepower – into the engine bay of the Focus. Although a handful of aftermarket firms have successfully mated Ford V-8 power with a Focus, the RS8 was built to show the versatility of a "Cammer" crate engine and "plug-and-play" engine electronics installation in a pure stock-looking Ford Focus.
The foundation of FRPP’s hot new 5.0-liter "Cammer" crate engine is rooted in the Ford SVT Mustang Cobra 4.6-liter four-valve engine family. However, the crate motor's flanged cylinder liners help provide 94mm (instead of 90.2mm) cylinder bores, creating a full 5.0-liters of piston displacement. And while the motor employs the 2003-04 SVT Mustang Cobra "Terminator" forged crankshaft with six-bolt mains and Manley "H-Beam" connecting rods for superior strength, the block itself is specially reinforced in the crankcase web areas for high torque loads.
Other key differences include forged pistons, an 11.0:1 compression ratio, ported heads, higher-lift cams and beehive-shaped valve springs. The crate engine also features higher-flow fuel injectors and a magnesium variable-geometry intake manifold, similar to the FR500 intake manifold currently offered in the 2004 FRPP catalog.
Ford Racing's new 5.0-liter "Cammer" crate engine comes with a stock SVT Mustang Cobra oil pan and exhaust manifolds, so an exhaust system – employing Ford Racing prototype metal-substrate catalysts and a set of Ford Racing dual-mode mufflers – was custom-fabricated to put the engine heat to the street.
One of the best parts about a Ford Racing 5.0-liter "Cammer" crate engine installation is that FRPP takes a lot of the guesswork out of the project by offering a choice of several length 5.0-liter 4-valve modular wiring harness kits that are created specifically to cover the most popular engine swap configurations. What's more, harness kits – which include the powertrain control module (PCM) – provide all of the necessary electrical connectors, including end terminals, a fuse box, a power distribution box, as well as switch connectors and fuel pump relays. The 5.0L EFI "Cammer" crate engine, including the wiring harness kit, will sell for a MSRP of $14,995 and will be available from the 2004 Ford Racing Performance Parts catalog.
Completing the RS8's powertrain is a Tremec five-speed HD transmission with a Ford Racing clutch kit and Ford Racing prototype shifter.
"Some sport-compact purists will likely never escape the four-cylinder mindset that keeps tuners and owners throwing bigger and bigger bucks at smaller and smaller performance gains," said Davis. "But we would like to think our 5.0-liter "Cammer" crate-engined Focus RS8 will somehow force the kind of performance paradigm shift that took enthusiasts from big traditional Muscle Cars to smaller, modern-day Pony Cars."
One look at the RS8 would suggest that its transformation from a production front-driver into a rear-drive pocket rocket was a study in simplicity. But in reality, Ford Racing engineers had their work cut out for them from the start.
Beyond fitting the drivetrain, there was the challenge of designing new suspensions front and rear. FRPP engineers put together a prototype setup inspired by Kugel Komponents up front, and a rear unit locating a Ford Racing 8.8-inch differential while offering adjustable ride height using Multimatic dampers. The newly-designed rear-wheel drive conversion kit will be sold through the FRPP catalog.
Four-wheel discs put the brakes on 18x8-inch European RS alloy wheels, wearing Michelin Pilot Sport 225/40 ZR18 tires up front and 255/45 ZR18s in the back.
"This isn't the typical sport compact modification project, but it sure will get attention out on the streets," exclaimed Davis. "With rear-wheel drive and over 400 horsepower, the Focus RS8 will make itself known at the drag strip and any road course. We're even going to take it drifting!"
Outside, the RS8 turns heads, thanks to the handsome European Focus RS styling cues and shimmering Blue Pearl Coat exterior paint treatment. Inside, the Focus RS provided the seating while Ford Racing chipped in with its Focus A-Pillar Gauge Pod and a full complement of Ford Racing Gauges. Also installed were a Harmon/Becker Traffic-Pro, a Sirius Satellite Radio system and Infinity amps and speakers – just to make sure the tunes are powerful, too.
FORD RACING FOCUS RS8 SPECIFICATIONS
Under the hood
• Ford Racing 5.0L "Cammer" crate engine
• Ford Racing 4V modular V-8 wiring harness
Estimated performance
• 420 horsepower @ 6700 rpm
• 370 lb-ft torque @ 5000 rpm
Powertrain
• Tremec five-speed HD transmission
• Ford Racing clutch kit
• Ford Racing prototype shifter
• Ford Racing 8.8" differential, 3.73:1 ratio
• Ford Racing prototype metal substrate catalysts
• Ford Racing dual-mode mufflers
Exterior
• Focus RS (European model) body styling
• SVT Focus Blue Pearl Coat paint
Interior
• Focus RS seating
• Ford Racing A-Pillar gauge pod
• Ford Racing gauges
• Harmon/Becker Traffic-Pro
• Infinity amps and speakers
• Sirius Satellite Radio
Chassis
• Kugel Komponents inspired Ford Racing prototype front suspension
• Ford Racing prototype rear suspension
• Multimatic adjustable dampers with adjustable ride height
• RS 18 x 8-inch wheels
• Michelin Pilot Sport 225/40 ZR18 Front; 255/45 ZR18 Rear
__________________
MarkSpark is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Unnofficial GT4 Car list.... MrFoggy Off Topic 30 06-10-2004 08:59 PM
Sport Compact Car Magazine bryan_giovana Protegé 5 (Protege5.com) 27 05-19-2003 11:14 PM
Why I had you take that sport compact car survey Grimace Off Topic 21 04-09-2003 01:51 PM
Sport Compact Car, whoz car? joshyellomp3 Mazda MP3 (MazdaMP3.com) 13 08-21-2002 02:46 AM
anyone raced in an actual sport compact car tournament 4DRMP5ATR Protegé 5 (Protege5.com) 7 03-23-2002 07:45 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
