Mazdas247.com The best prices on Wheels, Suspension, Exhaust + Brakes @ WheelDude.com!
Go Back   Mazdas247.com > All Mazda Tech > How-To
Notices
How-To How-To info for all Mazdas. To post a How-To thread in this Forum, please contact a Moderator or Admin for assistance.
Reply
Thread Tools Display Modes
Old 07-12-2003, 06:59 PM   #1
Brian MP5T
Banned
Brian MP5T's Avatar
Donated: $5
MP5T / 944
Thumbs up Installing A Tachometer
I've taken the time to write a kind of How To on a couple of subjects,
The first is how to install a tachometer adaptor on a 2002+ Protégé.
(THIS IS THE ONLY WAY I FOUND TO HOOK UP A BIG TACHOMETER OR SHIFT LIGHT) Others have found a wire from the ECU..
As many have noticed, the ignition system is a coil on plug system. Meaning instead of one coil charging up and feeding in this case four spark plugs, there are two coils independently connected to two spark plugs. When I first started out with my turbo install the stand-alone fuel management system needed a tachometer signal (usually a green wire). I thought that I could just connect it to the diagnostic plug mounted on the driver side strut tower, presto problem solved. Unfortunately the car is so new that all the old tricks have been replaced by technology. Basically here’s the solution. Autometer makes what is called a Tachometer Adaptor (PART #9117). It was $100.00 Canadian and was very simple to install. The unit is waterproof and has only four wires. Red, Red/Green, Black, Grey. On top of the engine are the two coils, you can’t miss them because they are covering two of the spark plugs and connected to the two other ones. Remove the split loaming and electrical tape that is covering the mess of wires leading to them. There should be three wires on each coil. A Positive, Negative and Trigger. The Positive is the wire that we want. It’s Black with a blue stripe. This is the same wire that feeds both coils. Cut the wire from the coils closest to the timing bulge on the cam cover. Be sure to disconnect both of them completely. The two wires still connected to the car both get connected to the Red wire on the adaptor and the other two still connected to the coils are connected to the Red/Green wire. Tape up your work and mount the adaptor away from the belts. Find a good ground for the Black wire and hook up your tachometer, shift light, or Tachometer Driven Stand alone fuel management system to the Grey wire. This is the only way to hook up a tachometer. If you bridge the wires to make one without the adaptor, you will fry the ignition system. If you only hook up one wire, you will only get half of the sparks being registered to your device. Motor at 2000 rpm = Tachometer at 1000 rpm. Included is a picture of the Tachometer Adaptor and the wiring schematic for the ignition system from the technical manuals. Feel free to ask me any questions. I’ve done my Turbo from scratch; many of the problems that I have already dealt with you might be dealing with now with no easy solution.
Later
Click image for larger version
Name:	brian's tachometer adaptor - (1).jpg
Brian MP5T is offline   Reply With Quote
Old 07-15-2003, 10:01 PM   #2
good0177
Registered User
good0177's Avatar
Hey, I was just going to ask about this because I plan on installing a Autometer Phantom Monster Tach w/ Shift light and was wondering about the coils. Can you perhaps include the wiring diagram and pics of your tach so I can get ideas of where to put it and how it looks in the car. Thanks for the write up man. Perfect timing. Peace.
good0177 is offline   Reply With Quote
Old 07-22-2003, 08:12 AM   #3
paladin
Ex MSP'r
paladin's Avatar
'03 evo
i see the pic looks nice
but no wiring schematic????
awesome job tracking that one down
ben
__________________
'03 EVO
paladin is offline   Reply With Quote
Old 07-29-2003, 09:50 PM   #4
tolmanron
Registered User
hi, i was wondering if i needed to use the tach adapter if i was just installing a tachometer w/o a shift light? i have a 2002 DX that did not come with a factory tach installed. couldn't i just hook the tach up to the wire by the diagnostic plug?
tolmanron is offline   Reply With Quote
Old 07-29-2003, 10:05 PM   #5
pdhaudio83
Banned
Donated: $10
Forum Crybaby
2001 Mazda MP3
i did that in my old sentra, except when i let off the gas, the tach went right to 0 rpms...
pdhaudio83 is offline   Reply With Quote
Old 07-29-2003, 10:07 PM   #6
pdhaudio83
Banned
Donated: $10
Forum Crybaby
2001 Mazda MP3
give it a shot, cant hurt, easy install too. just make sure u dont put it in the wrong plug, it might fuck stuff up (like me and my fuses i blew) lol
Old 08-02-2003, 01:31 PM   #7
MazdaProbeGT
It's just a DX...
MazdaProbeGT's Avatar
2002 MSP wannabe
Re: Installing A Tachometer
Quote:
Originally posted by Brian MP5T
(THIS IS THE ONLY WAY TO HOOK UP A BIG TACHOMETER OR SHIFT LIGHT)
Later
Um, what do you mean "only way"???
I just hooked up my tach the other day using the purple/white wire leading into the "diagnostics" box by the driver side firewall.
Works like a charm.
MazdaProbeGT is offline   Reply With Quote
Old 08-03-2003, 02:16 PM   #8
tolmanron
Registered User
Works like a charm.
i jsut hooked up my tach to the wire on the diagnostics box and it works just fine.
Old 08-03-2003, 02:17 PM   #9
tolmanron
Registered User
i just did the same thing and it works just fine as well!
Old 08-13-2003, 03:26 AM   #10
SpicyMchaggis
Banned
SpicyMchaggis's Avatar
Donated: 5$
so how do I hook up a tach? i have a 2002 DX as well..i need a tach..badly..
SpicyMchaggis is offline   Reply With Quote
Old 09-24-2003, 04:20 PM   #11
rosendo192000
Registered User
rosendo192000's Avatar
protege
Quote:
Hey tolmanron is right about that diagnostics box heres this thread i anwsed to.http://www.mazdamp3.com/vbb225/showt...threadid=31940
__________________
01 es protege
-skunk2 coilovers
-fiber images cf hood
-MHP CAIw/ AEM bypass valve
-rrracing upgraded rotors
-volk TE-37
-PIAA Super Plasma
-HKS hiper muffler
-vis carbon fiber trunk lid
CURRENT out of ORDER
rosendo192000 is offline   Reply With Quote
Old 12-10-2003, 11:57 PM   #12
NetGuy
Burnination!
NetGuy's Avatar
2006 Subaru WRX
Hey,
Maybe you guys can answer something for me...what's the deal with the Autometer Tach on a car that already has a tach in the cluster? Is it just for looks, or are they really that much better than the factory one? I like the shift-light, but I never understood the tach.
__________________
Still much love for the P5.
2006 Subaru WRX - TurboXS 3.5" turbo-back exhaust - Defi-Link Boost, EGT, Oil Temp in CF dash hood. Coming soon: TurboXS UTEC Delta ECU
NetGuy is offline   Reply With Quote
Old 12-11-2003, 09:00 PM   #13
rosendo192000
Registered User
protege
Quote:
Originally posted by NetGuy
Hey,
well i my self never had the autometer tach , i just had the shift light. dont really care for the big ass 5" tach
__________________
Old 12-12-2003, 06:59 AM   #14
Brian MP5T
Banned
Brian MP5T's Avatar
Donated: $5
MP5T / 944
Hey,
I guess it's supposed to be faster or more precise. I think they are Rice. To each his own. I bought a Proform Shift light. Took it apart, stuck it under the dash and wired it so it would light up a set of yellow LED's in my guage cluster. It does the trick and the car isn't cluttered with all that shit on the dash.
Old 12-12-2003, 07:02 AM   #15
Brian MP5T
Banned
Brian MP5T's Avatar
Donated: $5
MP5T / 944
Works like a charm.
I'm happy to hear of your luck. The tach adaptor works sweet too. For all of you that want info on it. if the thread is helpng, PM me.
Later...Brian
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Advice on new stereo install in a P5 allenpg Car Audio & Electronics 5 05-04-2003 09:46 PM
what is needed for an install slug420 Car Audio & Electronics 6 04-30-2003 10:26 AM
install questions PaulMP3 Car Audio & Electronics 10 04-22-2003 02:00 PM
MAZDASPEED install.... slug420 Car Audio & Electronics 0 10-05-2002 01:23 AM
How to install the Inidglo Guages??? DuCKieMP3 Mazda MP3 (MazdaMP3.com) 11 11-19-2001 04:09 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
