bewst12psi
- 93 Probe Turbo
SOLD SOLD SOLD For sale i have a fully built 2.0L FS motor. The block and head are from a 95 ford probe. Im pretty sure that if you plug the distributor hole, it works in Protege's
Specs from top of engine to bottom:
--Polished Valve cover with shaved emblems
--Tri-point engineering adj. cam gears
--Mike Seli cams .338/.343
--Solid Lifter conversion
--Eibach valve springs/ferrea SS valves/Paeco Magnesium retianers
--Bronze valve guides
--Ported Head by Schmidt Race Engines in Indy w/ 5 angle valve job
--ARP head studs with dead-soft copper headgasket
--.020 over block
--Ross Racing Forged Pistons/ Ross plasma-moly rings/ Ross wrist pins 9.0:1
--Custom made Forged Crower Con-Rods
--Lightened and Re-Balanced Crank
--ARP Main Studs
--Topline Timing belt kit and engine seals
--Toga HV Oil pump.
--Toga Performance Main and Rods bearings
--Oil Pan w/ Professionally welded in oil return bung --Fidanza 7lb flywheel
The engine has 27 miles on it...just to seat the rings.
$2300 obo.SOLD SOLD SOLD
SOLD -Trans- Cryo and peened gears, Escourt synchros, and a Closed Limited Slip Diff Made by OPM Autosport in Georgia. Its from a 2.0L 1995 ford probe. 35k before the rebuild....27 miles since. $550 oboSOLD
SOLD HiBoost Cast Turbo Manifold Thick heavy cast wont crack under any conditions. Has a T3 outlet and 38mm external wastegate flange. Never used $325 SOLD
ZEX Nitrous Dual Bottle Wet Kit Two 10lb bottles, complete kit with 35 50 and 75 jets... never used $500
Big FMIC NEW. 28/11/4 with 3inch inlets. $175
all items are PLUS SHIPPING AND PP FEES.
Text @610-790-3388 or email @joepianka@yahoo.com
thanks
--.020 over block
--ARP Main Studs
--Toga HV Oil pump.
