Mazda Forums Show your support and Donate!
Go Back   Mazda Forums > Marketplace > New Gen Mazda For Sale > MAZDASPEED3 (MS3)
Notices
Reply
Thread Tools Display Modes
Old 10-23-2009, 01:37 PM   #1
RichB
Registered User
RichB's Avatar
FS: 7-Inch In Dash Touch Screen - SOLD
Up for sale is my 7 inch Double Din touch screen radio. I bought this radio about 2 months ago with the hopes of getting Magden gauges but that fell through which is why I am selling this radio.
Features include:
*Built-in Bluetooth /TV tuner /AM/FM
*iPod interface ready (cable included)
*Compatible with DVD, VCD, CD, MP3, MPEG-4, CD-R, WMA, and JPEG playbacks
*Supports CDC
*USB port and SD card slot
*Intelligent steering wheel control
*Electronic anti-shock protection
* Full function remote control
There are 2 AV outputs, aux audio and video input, and RCA audio output. This radio does not have GPS software preloaded.
Note: This radio does work with Bose but requires a wiring change. Let me know if you will be using this with Bose.
I am looking for $325 Shipped. PM me if you're interested. Thanks
__________________
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is online now   Reply With Quote
Old 10-23-2009, 02:54 PM   #2
mazdaspeed32007
Registered User
mazdaspeed32007's Avatar
what would be the estimated costs for the gps and antenna? i have a huge sd card and wouldnt mind buying this unit pending gps pricing. how much did you pay for this head unit btw?
__________________
Cobb AP Stage 2, PG FMIC, Cobb Turbo Inlet, Forge BPV, AWR Rear MM, Denso 1 Step Colder Plugs, Corksport DP, PTP Internals, PTP Windage Tray, PTP B/S Delete, No Show License Plate Holder, Pypes Mini Cat, Custom MSCAI, Painted Calipers/Front Grill/Bottom Lip, Apexi Turbo Timer, TWM Shifter Bushings, Oil Filter Conversion, Prosport Sandwhich Plate, Center Triple Gauge Pod (Oil Pressure, A/F and Boost), Rota Tarmac 3 Bronze Rims 18x7.5, 20% Tint, Demon Eyes, Eyelids, MT-90 Tranny Fluid
mazdaspeed32007 is offline   Reply With Quote
Old 10-24-2009, 09:31 AM   #3
RichB
Registered User
RichB's Avatar
I did more research on the GPS antennas and this Radio doesn't have a place to connect an external antenna. You can still load the GPS software using an SD card but I am not sure how good the signal would be.
I updated my original post and reduced the price some more. Any questions, let me know.
__________________
Old 10-24-2009, 11:55 PM   #4
mazdaspeed32007
Registered User
are you sure you saved the updated post? i believe it was 350 when i saw it b 4
__________________
Old 10-25-2009, 01:13 AM   #5
vtakk
Registered User
vtakk's Avatar
can you fire it up and post interface pics?
as well as front pic;
I'm surprised you said there is no jack for gps antenna;
bump for updated price too if any.
vtakk is offline   Reply With Quote
Old 10-25-2009, 08:43 AM   #6
RichB
Registered User
RichB's Avatar
Quote:
It went from $375 to $360 now to $350 but if you make me a good offer we'll see.
__________________
Old 10-25-2009, 08:44 AM   #7
RichB
Registered User
RichB's Avatar
I didn't get the GPS option which is probably why it doesn't have the antenna jack. Here it is in my car:
You want me to get a pic of the back too?
__________________
Old 10-25-2009, 09:02 AM   #8
mazdaspeed32007
Registered User
wierd it has a gps touch option right on the main screen with no gps jack....i dont get it.
it only states gps via sd card in the user manual? if this is true has anyone had any experience withgps via sd card?
__________________
Old 10-25-2009, 10:34 AM   #9
RichB
Registered User
RichB's Avatar
Yea, it will load the GPS software with the SD card but when you look through the manual it says that the Antenna connection is optional.
__________________
Old 10-27-2009, 07:27 AM   #10
RichB
Registered User
RichB's Avatar
Bump. Price updated!
__________________
Old 10-29-2009, 01:34 PM   #11
vtakk
Registered User
vtakk's Avatar
Quote:
so did you try loading SW and see if it finds satellites?
if so there is everything in place but external antenna jack can be always soldered in - should not be a big problem.
can you confirm gps sw actually receives data?
Old 10-29-2009, 05:50 PM   #12
RichB
Registered User
RichB's Avatar
I have not tried to load the software myself but this unit has a SAMSUNG S3C2440A-40 Chip set with the following features:
*GPS Store space Main frequency: 400MHZ
*Memory: 64MB
*Store space: 64MB (can external to 4GB)
*Navigation software store: SD card
*Operation system: WINCE5.0 CORE can read 3D map
Any GPS software that works with Windows CE 5.0 will work with this radio.
__________________
Old 10-29-2009, 07:06 PM   #13
vtakk
Registered User
vtakk's Avatar
*Memory: 64MB
well we're talking about different things here: would the sw run and second which is most important - would the sw detect hardware and receive coordinates etc.
I bet IGO for instance would be running fine but would it function? that's the question.
if there is gps hardware in this unit then you may try selling it for what you ask (or even more) but if not it may not be that interesting deal for the price (for roughly hundred and fifty more you get new unit with gps and better screen resolution, better sw etc);
I understand you took it off already but I think any potential buyer would like to know the answer to above questions. just my two cents here
Old 10-29-2009, 10:07 PM   #14
RichB
Registered User
RichB's Avatar
I thought I was answering your question but I will try to clarify. Yes I think the software can be loaded and yes I think it will run. When I go to the GPS option on the home screen it tells me that the SD card isn't installed. The only thing that this unit is missing is a connection for an external GPS antenna.
The only thing I am uncertain about is if you need an external antenna for the software to work correctly. What I do know is that an External GPS antenna connection was an option that is not included with the radio I am selling.
Did that answer it?
__________________
Old 10-29-2009, 10:33 PM   #15
vtakk
Registered User
vtakk's Avatar
Did that answer it?
sw can run but if there is no gps hardware you will have no data.
I honestly don't think someone would include/exclude just antenna when selling such units. It does not make much sense to me. But China is country of contrasts lol so everything possible )
if you run gps sw and it reads you location then it should not be a big deal to wire external antenna. But answer is not clear if sw would receive data or not. And this is the key question.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My New Touch Screen RichB Mazda3/MS3 Car Audio & Electronics 21 08-30-2009 12:14 PM
Who has the OEM touch screen....? DMRH CX-7 Car Audio & Electronics 0 02-19-2009 07:49 AM
Touch screen DVD player with NAV obaidnsk CX-9 Car Audio & Electronics 0 05-20-2008 06:11 AM
Hmmm... think this will fit a 7" touch screen? ZoomRedZoomGT Mazda3/MS3 Car Audio & Electronics 4 01-24-2007 06:34 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2009, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
