![]() JSCspeed.com - Your Source for IN STOCK Mazda Performance Parts! |
#1 |
Registered User
Authorized Vendor
Hi,
Tired of cheaply made kit that have bulbs flickering, bulbs turning off by themselves or simply a part failing every 3 months? Don't have the money to buy an Xtreme kit with Philips bulbs? No problem. Just in time for the Holidays we are introducing the Volt HID kit. Japanese parts, low draw and bulletproof reliability. Say goodbye to problematic HID kits!!! Volt HID Kits offer the latest in High Intensity Discharge (HID) Xenon technology. Volt HID utilizes ultra slim-line ballasts with next generation patented Digital+ technology for optimal light output and ballast efficiency. This exclusive HID conversion kit is the leader in digital ballast technology and will provide you with a level of performance and quality that is unmatched by similar digital HID products found on the market today. Volt HID Digital+ ballasts are the smallest and lightest ballasts manufactured today. This new ultra-slim design will enable the product to be used in a wider variety of applications. - Patented Digital+ technology for optimal light output & ballast efficiency - Ultra-slim design and light weight ballasts - Quality Japanese parts - CE, UL, and E4 certified OEM Grade Xenon HID Components - Rubber injected waterproof/shockproof ballasts - Laser aligned HID Xenon Bulbs to ensure optically correct beam patterns - Full 1 year replacement warranty BALLAST SPECIFICATIONS: -These ballasts are equipped with next generation Digital+ Technology allowing the ballast to exert greater control over electrical flow to the bulb. As a result, the voltage output to the bulb is more consistent and stable, resulting in constant lumen output, brightness stability,with no flickering or one side not lighting up unlike some thin ballast designs on the market. - Automatic reverse polarity protection. - Dual EMI Filter protection Circuit shielding. - Ultra-slim design and light weight: Our ballast measures 3" x 2 5/8" x 9/16" (7.6cm x 6.6cm x 1.4cm), and weighs only 7 oz (200 g). - Volt Digital+ ballasts are uniquely designed for aftermarket applications as they are rubber injected to protect against harsh weather conditions[/b] To ensure optimal light output, the Volt HID Kit uses laser calibrated bulbs so that the focal point of the HID bulb matches the focal point of the corresponding halogen bulb. This will result in both proper fitment and optically correct beam patterns. These bulbs are rated at approximately 2500 hours of use – same rating as high end Philips and Osram bulbs. Industry leading AMP style connectors are used to ensure proper water tight connections. Volt HID is manufactured in an industry leading high tech facility. Due to stringent manufacturing standards, this product line carries ISO certification, CE and UL safety listed, and is E4 certified. This product carries a one year legitimate warranty. LIMITED TIME OFFER: $120 USD Get it here: http://www.xenonexpert.com/volt_hid_sale.html ![]() ![]() ![]() ![]() ![]() Get it here: http://www.xenonexpert.com/volt_hid_sale.html Enjoy! Oliver |
#2 |
Registered User
Authorized Vendor
Pms replied and more tracking sent!
__________________
Sigs are visible only in your first post on a page. To change your thread display preferences, click here and enable 'Always Show Signature'. |
#3 |
Registered User
Authorized Vendor
Pms replied. Bunch of tracking sent
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| VOLT HID *Japanese* slim kit!!! Sale XENON EXPERT | Xenon Expert | Mazda6 & MAZDASPEED6 (MS6) | 2 | 11-12-2009 12:36 AM |
| VOLT HID *Japanese* slim kit!!! Sale XENON EXPERT | Xenon Expert | MAZDASPEED3 (MS3) | 3 | 11-12-2009 12:33 AM |
| VOLT HID *Japanese* slim kit!!! Sale XENON EXPERT | Xenon Expert | Mazda5, MPV & Mazda Trucks | 2 | 10-22-2009 01:19 AM |
| VOLT HID *Japanese* slim kit!!! Sale XENON EXPERT | Xenon Expert | Mazda6 & MAZDASPEED6 (MS6) | 3 | 07-02-2009 11:50 PM |
