Before this shoot found out the inner CV boot on my left axle split. On the way back from this shoot i blew my front right BC coilover sturt hitting an uneven road surface
You continued driving on a torn CV boot? I guess you decided to swap out the entire axle instead of just the boot then.
My CV boot on my Subaru was torn prematurely due to the aftermarket DP being closer to it than stock. Was it the passenger one by chance - this assuming you're running an aftermarket DP.
Sweet-looking rides BTW.
yeah it wasnt making any noise yet and the grease looked fresh. it is currently at the shop getting the boot replaced.
no those are potenza pole position a/sAre those stock tires on the MS3?
no, i could use some spacers in the front still but i did use camber arms in the rear and they stayed nice and flushAhhhhh this is what I wanted to do with my MS3. Did you do 15mm spacers? Both cars look great man.
