![]() Show your support and Donate! |
#1 |
16.81@81.8mph 1.8l
Slotege KLZE Swap Thread
Well, here's the plan. It has been done before I know so I'm not the first, however I would like to share everything going on so far just due to the fact that it is barely talked about here on Mazdas247.com. So, I am including my parts list, prices, pics, trouble i run into, work arounds, and other helpful info. So look at this as a Write-Up How To/Build Progress Thread.
Goal: Swap a Straight Neck KLZE 2.5L V6 into my 2000 Mazda Protege LX to replace my dieing 1.6L ZMDE. Part List: Engine - KL-ZE Straight Neck - Bought - $880 Shipped Transmission - Used MX-6 Transmission - Bought - $150 Picked Up LSD - Used Mazdaspeed Protege LSD - Bought - $230 Shipped Speedo Drive Gear - Mazda OEM New - Bought - $14 Shipped Clutch - South Bend Rally Series Stage 1 - Bought -$196 Shipped Flywheel - Stock OEM Mx-3 GS 1.8l v6 KLDE/ZE Gasket Kit - Bought - $55 Shipped 1994 KLDE 8-Bolt Crankshaft Spacer - $20shipped Power Steering Reservoir - Bought - $24 Shipped ECU - KL31 Wiring Harness - MX6 LS 93/94 OBDI - Bought - $128shipped Distributor - MX6 LS 93/94 OBDI - Bought - $85 shipped Universal Tach Interface - Dakota Digital SGI-8 - Bought - $75 Shipped Passenger Side Mount - 2.0l Protege OEM or SLS Mount VAF - Mazda JE50 - Bought - $50 shipped VAF - Mazda KL03 - Bought - $35 Shipped Headers - PaceSetter Normal Coated wrapped with Header Wrap Intake - Aftermarket Cold Air from MX6 Battery - Slim Odyssey PC680 for fitment issues - Bought - $129 Shipped Radiator - OEM from a 2g MX-6 LS - Bought - $60 Picked Up Intermediate Shaft 2g MX-6 LS - Bought - $30 Picked up Starter - 2g MX-6 LS - Bought - $40 Picked up Power Steering Reservoir - OEM 2g MX6 LS - Bought - $19 Shipped Axles - Both side 2.0l Protege axles Timing Belt Kit w/ Early Style Water Pump O2 Sensors - OEM MX6 Upstream sensors Gaskets - Complete Engine gasket set - Bought - $50 Shipped More small stuff.... Notes: 1. When buying a valve cover, head gasket, intake manifold, and exhaust manifold set; make sure that the set includes the intake manifold gaskets for a ZE as well. There is a big difference between ZE and DE manifolds. Exhaust manifolds should be the same. Total: $2,249.63 to date more to come Pics: Radiator - 2G MX6 LS 2.5L V6 ![]() VAF - JE50 ![]() Universal Tach Interface - Dakota Digital SGI-8 ![]() Straight Neck KLZE from an Automatic - Bought from JDMEngineZone.com Arrived ![]() ![]() ![]() ![]() ![]() ![]() Head Stamping - KL31 1A1 and KL31 101 ![]() ![]() Cam Stamping - KL31 ![]() Above ![]() Random ![]() Gaskets and junk ![]() Zip-loc + marker = Saved time ![]() ![]() result after Day 1 ![]() More & Progress Parts 7-23-2009: Prosport Oil Sandwich Plate ![]() Odyssey PC680 Battery ![]() New Slave cylinder ![]() Painted the valve covers-its bronzey silver, but the camera picks up mainly the silver, very cool color though ![]() Intake Manifold Before: ![]() Throttle Body Before: ![]() Intake Manifold and Throttle Body After: ![]() Prosport Electrical Oil Pressure Gauge and ForceFed Gauge Pod: ![]() Transmission Before/During De-greasing: ![]() Transmission After, not perfect but definitely better: ![]() Clutch, Speed Gear for Transmission after differential install, wheel well plastic to replace my torn one: ![]() DXD Southbend Rally Series Stage 1 Clutch: ![]() Mazda KL02 VAF from US 2.5 in case I need to go with a US Ecu for a bit or decide to go with a chipped us ecu: ![]() Mazda KF34 Distributor from US 1994 MX-6 LS: ![]() Stock Fuel Rails and Injectors, painted a Mazda6 red with a lot fo metallic in it, I will try and get a better pic showing the metallic: ![]() Quick Mock up of the current progress: ![]() 7/29/2009; Finally got my engine stand, Oil pan off and everything inspected; looks all good: ![]() Block all degreased, and almost ready for paint: ![]() Much neater now that the pallett is gone and everything is organized: ![]() Bonus Pics: DSM Wreckage in my friends garage where we are working on the KLZE; 7-bolt DSM + crank walk + 27psi of boost for three weeks on stock tune = This: ![]() ![]() Worked on the vacuum plumbing Old tubing that was hard as a rock: ![]() New tubing all in place: ![]() New fuel line on the end of the rails, and another view of the completed intake manifold: ![]() Painted the heads and block: Block looks weird in the pic its a much darker color in person, flouresent lights trick ya along with flash: ![]() Used MSP Limited Slip Differential ![]() more to come....
__________________
![]() 2000 Mazda Protege ES 1.8L KYB GR-2 w/ Eibach Pro-Kit Springs Cosrksport Strut Bar, Racing Beat Rear Swaybar AWR 95duro FMM, AWR Tranny Inserts Hardrace Front Control Arms Techone 7000k H4 BiXenon HIDs OEM Mazda Fog Lights w/ 3000k HIDs Odyssey PC680 Slim Battery 2003.5 MSP Floormats JDM FD3S Nardi Torino Steering Wheel 01-03 Sedan Front Lip Modded to fit 99-00 Bumper 03 ES "Protege" Badge, 03 ES Rear Spoiler C/F Trunk Trim, DGM C/F Arm Rest and Glove box Trim Rest of the mods from the oldie are coming. KLZE Project Underway FS: The old Slotege Partout WTB: 01-03 2.0l Transmission Bracket, Passenger 2.0l Axle 2000 Mazda Protege LX: - RIP 8-1-2009 Last edited by IukekiniProtege; 12-21-2009 at 04:41 PM. |
#2 |
16.81@81.8mph 1.8l
Here is the result of this past weekend. Project is temporarily put on hold.
![]() ![]() ![]() ![]() ![]() September 15, 2009: New Slotege - Slotege_1.8 ![]() 9/11/2009: Day after I got it: ![]() ![]() ![]() Today - 9/15/2009: ![]() ![]() Clear coat issues on trunk: ![]() Old one repainted by my friend, ready to install: ![]() Interior:
__________________
Sigs are visible only in your first post on a page. To change your thread display preferences, click here and enable 'Always Show Signature'. Last edited by IukekiniProtege; 09-15-2009 at 06:00 PM. |
#3 |
16.81@81.8mph 1.8l
Reserved 2
__________________
Sigs are visible only in your first post on a page. To change your thread display preferences, click here and enable 'Always Show Signature'. |
#4 |
16.81@81.8mph 1.8l
Reserved 3
__________________
#5 |
Registered User
i cant wait
#7 |
16.81@81.8mph 1.8l
im plannign 3-4 weeks for everything to be ordered and arrived and ready to go in, then we are dedicating a Fri, sat, sun to the swap.
__________________
#8 |
Registered User
wish it was me...do get scooby's turbo also........plz
#9 |
IT > me
FS, MSP & Wisconsin Moderator
sub
__________________
Exedy|GTSPEC|EBC|Spool|AWR|Greddy|HKS|Vibrant|MAM| ProSport|ForceFed|DaveB|Snap-On|DG|BlueBatmobile | And custom work whenever I can
#10 |
Ride Sunday! Bikes
sub
__________________
'03 ESMSP round axle back muffler MSP suspension (blues, and racingbeat springs) AWR 21.5 mm rear sway bar MP3 Rear Spoiler Alpine 9880 Head Unit Alpine type R 10" sub and 1800 watt kenwood amp Charcoal Grey MSP Racing Hearts Weapon R Dragon Air Intake Custom column gauge pod (painted 25f) OBX header 93 Miata Koni Yellows Ground Control springs (450,375) ASA 10 Spoke wheels Sparco Sprint V seat Takata 4 point harness |
#11 |
BEAST Mode: [ON] OFF
Subbin'
__________________
- el Don 2002 Protege ES Painted Red Calipers Painted Red Valve Cover INSYSUSA Short Ram Intake MSP Front Strut Tower Bar (w/ Cruise Control) 2003.5 MSP Shift Knob Wagner Shorty Header Techone 4000K BiXenon HIDs 2001 MP3 Racing Beat Axle-Back Exhaust DaveB Gauge Rings Nardi Torino Steering Wheel KartBoy Short Throw Shifter Medieval Crank and Water Pump pullies |
#12 |
Think with your disptick!
For Sale & Protege5 Moderator
This will be another KL swap to envy. Congrats on the purchases man. The bump in power will be enormous.
__________________
#13 |
16.81@81.8mph 1.8l
Parts list mostly added, left out stuff liek clamps, hoses, and other stuff, if you curious to see the spreadsheet I can post a link to it.
__________________
#14 |
wanna be mspeeee #1
yummy
__________________
#15 |
2+2=Vagina?
subin
__________________
Me ![]() Powered By: Tokico - Skunk2 - Konig - General Tire - HIDExtra - Corksport - Mazdaspeed - Injen - MazdasNW.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| KLZE swap | s0n1cm0nk3y | 3rd Gen Engine & Performance general | 1 | 09-20-2008 02:06 PM |
| need help about a klze swap | cantstopklze | Protegé 5 (Protege5.com) | 0 | 03-30-2008 06:08 PM |
| klze swap | cantstopklze | Protegé 5 (Protege5.com) | 10 | 03-07-2008 03:21 PM |
| Looking to swap for klze or de | horaaan16 | All Mazdas & Classic Mazdas (ClassicMazdas.com) | 0 | 10-06-2007 04:55 PM |
| KLZE swap? | enzo ferrari | Protegé based Performance | 5 | 04-19-2004 05:19 PM |
