Mazda Forums In Memory of Mazda Forums member "1338".
Go Back   Mazda Forums > Protegé, Familia & Mazda Family > MAZDASPEED Protegé (MSProtege.com) > MSP Engine, Performance & Forced Induction
Notices
MSP Engine, Performance & Forced Induction Intakes, exhaust, general performance and engine discussions. *Threads not MSP specific will be moved.*
Closed Thread
Thread Tools Display Modes
Old 03-08-2009, 08:56 AM   #1
Mazdaspeed2oo35
474.8whp/396.6wtq @ 25psi
Mazdaspeed2oo35's Avatar
Mazdaspeed2oo35 Engine Build Round 2
After removing the engine head to replace my bad head gasket i have decided to move to a higher stage to gain more horsepower also in a more and effective way. The performance shop that is going to do my next build are specialized in World Rallye cars and hi performance engines here in Spain, after few hours of planning, measuring and calculating they have come to the conclution that we have the supported parts and engine management to produce well beyond the power the car were producing before to be exact 474.8whp and 390 lbs torque, at 26 P.S.I using methanol Injection. They have planned our next project.
* 0.20 Custom low compression Racing Pistons 8.0:1 (made in Germany)
* Engine block and crankshaft work to shops performance specs
* They are also doing some work to the Turbo to make it spool earlier and to be more powerful up top.
* ARP Head and Main Studs.
* Custom Quad-Metal Bearings (made in Germany)
* Custom made to specs performance head gasket (made in Germany)
* Complete DOC B FS-DE Performance oil System
* AWR deep sump oil pan
* 4 new OEM Mazda Engine block Oil Squitters
* Custom Racing engine oil cooler (made in Germany)
* Custom Racing transmission oil cooler (made in Germany)
* Lighter Engine Pulleys (made in Germany)
* 505zoom Intake Manifold ( made in USA ) lol lol
* ACT Custom made Xtreme Pressure Plate with also Custom made 6 Puck Racing clutch made to order by ACT, according to them this Clutch and pressure plate were made to hold over 500 lbs of torque.
The Shop that is doing my car also makes Custom LSD's, as well as custom Straight cut gears, we are going to replace my OEM welded LSD for a custom made by them, also all of the gears in straight cut with custom ratios, and a taller 5th gear, they are also doing some work to the transmission case in order not to crack or break it, something like PAR offers for the casing of the Transmission.
The project have been set to run a constant and efficient boost between 2 and 2.5 bar, if not mistaken that's between 30-35 PSI of boost on methanol and around 600whp+ and over 450 lbs torque... I'll post specific specs and info once we start this new project of mine but basically they are going to build a Racing Track car to be driven on the Streets..
I'll post pictures later when i go back to the shop.
__________________
Daily Driven Garrett GT3582R Turbo Mazdaspeed Protege (Built not Bought)
Cardomain Website: Http://www.cardomain.com/ride/2315771
Mazdaspeed2oo35 is offline
Old 03-08-2009, 10:11 AM   #2
MikeLikesMazda
Destroyer of Worlds
MikeLikesMazda's Avatar
... holy shit. i want to see a video when its done lol. good luck man
__________________
Quote:
Originally Posted by CWPspeed3 View Post
I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
freshly boosted
MikeLikesMazda is offline
Old 03-08-2009, 10:11 AM   #3
.mazda.speed.
*I Am Addicted
Yourt car is fast enough,
Make mine faster!!!
Just kidding dude, that sound SWEET, Can't wait to see when its done. Hopefully some new video's.
.mazda.speed. is offline
Old 03-08-2009, 11:22 AM   #4
boostdprotegelx
Damian
boostdprotegelx's Avatar
Ren lookalike
i'm gunnin for that power too bud!! woot. hopefully we both hit our goals!!
boostdprotegelx is offline
Old 03-08-2009, 01:40 PM   #5
Outlawstar98
٩(̾●̮̮̃̾•̃̾)۶ mE hz mOd?ż
Outlawstar98's Avatar
MSP, Delaware, New Jersey & Pennsylvania Moderator
good luck man! I wish I just had 400+hp haha
__________________
٩(̾●̮̮̃̾•̃̾)۶ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.
Outlawstar98 is offline
Old 03-08-2009, 02:48 PM   #6
Mazdaspeed2oo35
Thanks guys i really appreciate all of you guys support and words, they help me to keep going and to keep representing all of my USA Mazda Protege brothers here in Europe. Some might think I'm insane by spending the money i did and the money i will this time, but i know once again that at the end will be well worth it..
__________________
Old 03-08-2009, 02:58 PM   #7
Maxx Mazda
Haltech Guru
Maxx Mazda's Avatar
Donated: $10
Did you ever figure out those piston problems you asked me about in that PM?
__________________
Maxx Mazda is offline
Old 03-08-2009, 03:00 PM   #8
Mazdaspeed2oo35
Quote:
yeah Maxx, the problem was T*K Per******nce.... I paid them to do work on my block and simply they did a poor shitty work, Well I'll PM you about it. i don't want to talk bad about someone that is not even worth the time...
__________________
Old 03-08-2009, 03:24 PM   #9
dstmsp03
Registered User
dstmsp03's Avatar
damn.. i wish i made your money to do all this!
__________________
Mods: Fmic with Greddy Type RS BOV, GHL 3inch exhaust, Twiggy Turbo Cams, Garrett GT2871R turbo, Thunder Turbo manifold, 626 Single runner manifold, Perrin Fuel rail with Pressure gauge, SU front and rear motor mounts, GTX 3rd and 5th gears, Welded LSD, Fidanza flywheel, Spec Stage 2+ clutch, GT Spec Front strut bar, short throw shift, ion lowering springs, Aluminum ADP, twin 12inch slim fans, erebuni reverse dual cowl hood, DG carbon fiber shift surround
dstmsp03 is offline
Old 03-08-2009, 03:29 PM   #10
Mazdaspeed2oo35
Quote:
Nah bro, I'm a simple hard worker like any of you guys in here, just once again i was lucky i sold my Escort RS Turbo i had in here, a very very rare care for a good amount of money plus a little saved up money i had hidden lol... I'm not paying for Labor, this Shop is from my best friend and they are sponsoring me by now with free labor and some good discounts on the parts and shipping from England and Germany
__________________
Old 03-08-2009, 03:33 PM   #11
Mazdaspeed2oo35
Nah bro, I'm a simple hard worker like any of you guys in here, just once again i was lucky i sold my Escort RS Turbo i had in here, a very very rare care for a good amount of money plus a little saved up money i had hidden lol... I'm not paying for Labor, this Shop is from my best friend and they are sponsoring me by now with free labor and good discounts on the parts and shipping from england and germany
We are also going to do some adjustments in the suspension because i'm going to track this car this time, they want to make this car a Track headache monster, and a street driven devil. I'm also waiting for price on some 14" racing brakes from Germany as well.
According to them they want my car to be their shop image in shows, track and competitions as a full interior car and daily driveable since nobody owns this car in Spain and very very possibly in europe legally registered
__________________
Old 03-08-2009, 04:22 PM   #12
Rogue
Red 5 Standing by
Rogue's Avatar
Donated: $15
Do you plan on tracking/road racing the car?
Rogue is offline
Old 03-08-2009, 04:30 PM   #13
Maxx Mazda
Haltech Guru
Maxx Mazda's Avatar
Donated: $10
Got your PM. Hate to say it, but those guys are MAD shady ever since day one.
I watched some of your videos... Um... You need better brakes man, with a car that fast, you NEED a BBK. Trust me, best investment I ever made.
__________________
Old 03-08-2009, 04:32 PM   #14
_Slotegé_
Protegé Type Arrr
_Slotegé_'s Avatar
Donated: $20
WOW your next build is going to be sick!
Goodluck with everything!
__________________
_Slotegé_ is offline
Old 03-08-2009, 05:00 PM   #15
Mazdaspeed2oo35
Quote:
Actually yes, I'm going to Track this car, we have some nice tracks in here In Spain, also i want to do road racing as well.. when ever the car is done and fully adjusted engine and suspension wise i'm going to test drive in on a Private Track this people have to test their asphalt rallye cars..
__________________
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS-ZE engine build mp3moose Protegé based Performance 35 09-19-2009 06:20 AM
Engine Build spicyprotevo MSP Engine, Performance & Forced Induction 13 10-18-2008 09:26 PM
Engine Build Help jwehrheim MSP Engine, Performance & Forced Induction 7 07-02-2008 01:21 PM
Engine Re-build Kit juansprotege88 MSP Engine, Performance & Forced Induction 1 06-03-2008 01:43 AM
Engine Build hoth Protegé 5 (Protege5.com) 5 04-24-2008 02:49 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
