Mazdas247.com Get your 2010 MAZDASPEED3 Short Shifter @ TWMperformance.com!
Go Back   Mazdas247.com > Mazda Family > MAZDASPEED3 & MAZDASPEED Axela (MZSPD3.com) > Mazda3/MS3 How-To
Notices
Reply
Thread Tools Display Modes
Old 02-10-2008, 12:10 AM   #1
Bravnik
Registered User
Bravnik's Avatar
How To: Shift Beeper Install
The product installed is Modfry's Redline Shift Beeper:
http://www.modifry.com/products/rlb/...nual%201.8.pdf - PDF of the install instructions on an S2000. There are none for the MS3 other than the ones I'm writing now
Please Note: You will need to send a mail to Modfry before ordering as the install on our car requires a 1 cylinder setting as you will be using the MSD GMR 8918. Bob can easly do this for us but its custom (no extra charge) and will be sent ready to go at 1 cylinder. So please be sure to send Bob a mail before you order a Redline Shift Beeper!!!!!!!!!!
You will also need a MSD Tach GMR 8918 for this installation:
http://www.msdignition.com/2006/06-22.htm
To begin the installation you will need to remove your TMIC - This is very easy and you should never require instructions for this. Locate the 4th coil from the left:
Cut the plastic cover to expose the GREEN wire. This is the wire you will clamp the MSD GMR 8918 too:
With the GMR Clamped in place:
Once clamped in place run the GMR wire to the Fuse Box. I ran it around behind the battery box and then along the side. Then reinstall your TMIC as you're done with this part of the engine.
You will need 2 Add-A-Fuse adapters for this nexxt part of the project:
Remove the cover on the Fuse box and insert the first add-a-fuse into one of the 2 empty fuse spots closest to the front of the car. This one will connect to the Red Wire on the MSD GMR 8918.
(note the pic has both Add-A-Fuse's in place)
You will then need to ground the Black wire on the GMR 8918 to where the Neg Post of the Cars Battery is gounded. This is on the fender wall. Sorry I forgot to take a pic but just follow the Car's Neg Post cable and you can't miss it.
Next install the 2nd Add-A-Fuse. This will be used for the 12v Switched power for the Redline Shift Beeper installation:
Now you will need to run 2 wires from inside the car into the engine bay via the Hood Release cable hole in the firewall. Taking pics of this was tight so I didn't even try. Basically follow the hood release cable to where it enters the firewall. Pull the carpet away and you will see the hole. Its pretty big and easy to run stuff through. I use a 2ft length of copper tubeing as its stong enough but very flexable as well but you can use a coat hanger if you need too.
Tape 2 wire ends to the coat hanger or copper tubing or whatever your using and run it into the hole and UP. This will come up behind the cars Battery Box so its best if you remove the lid to the battery box. Just pull the wires through when you see them.
I used a Red Wire (22g) for the 12vs and Green (22g) for the Tach Signal Wire on the GMR. Connect the green wire to the Green Wire on the GMR for the Tach Signal and then connect the Red wire to the 2nd Add-A-Fuse. Clean up your wires and put the batter box lid on as well as the fuse box lid as you're now complete under the hood of the car:
Inside the Car Now:
Ok so now you should have a 12v and Tach Signal coming into the car via the Firewall Hood Release hole and down onto the drivers side floorboard.
The first thing I did was find a location for the Redline Control Module. If you're looking from the floor up under the driverside dash, I placed my module on the far left side. I used Velcro to put it in this location and ran the wires from the left (center console) to the right (door panel).
I ran the wires from the module across towards the drives side kick panel and then zip tied them into place. I did this so I can pull the module down when I wanted to adjust the RPM settings and I would have plenty of slack.
I then used velcro again to mount the Speaker for the beeper a little deeper into the dash under the stearing wheel. (Note: You can barely see it behind the wires in this pic. It is a round white speaker with a Red and Black wire).
Once done, it was time to do the final connections:
You will now connect the 12vs Red wire you ran from the engine bay to the Red Wire on the Redline Module as well as the Red Wire coming from the Speaker.
You will then need to connect the Green wire coming from the Engine Bay to the WHITE wire on the Redline Module.
After this is done, connect the BROWN wire on the Redline Module to the BLACK wire on the Speaker.
Once complete the only wire you need to worry about now is the BLACK wire on the Redline Module which is the Ground. I removed the drives side kick panel and grounded the Module at the ground spot under it. You can't miss it. You just need to remove the kick panel and you will see it easly. Sorry I forgot to take a pick of this.
Now you're done. I didn't connect the BLUE wire or the Green wire on the module as its a switch that will tell you the highest RPM attained. I found this useless to me but if you want too you can.
Now I set my RPM setting on the Module to 5.5k
I took her for a spin and was happy when everything worked without any issues at all. I LOVE the end result and if others decide to do this install as well, I hope this DIY helps you out.
__________________
2007 BM MS3 - ATP FMIC - Cobb SRi - Cobb Turbo Inlet - CPE Catted DP - HKS BPV - Cobb AP - Denso Plugs - PTP Fuel Pump - Cobb STS w/Bushings - Cobb Shifter Weight - Cobb RSB - Eibach Pro Kit - Prosport Boost/Oil Gauges - DashHawk - Tenzo Type M (Bronze) - Redline Shift Beeper - No brand loyalty, if it works I use it.
Bravnik is offline   Reply With Quote
Old 02-10-2008, 03:28 PM   #2
GhostMercury
Street Feet
GhostMercury's Avatar
MazdaSpeed 3 08.5
that is pretty usefull. is the install as hard as it seems
__________________
Owning the first 08.5 in MN...Priceless!!!!!
DEFI Boost Gauge/D-Link - Tint - LaminX Headlight Film - Rear Bumper Protector - CPE Engine Mount - TWM Desert Eagle Shift Knob - TWM Shifter Bushings - Under Dash/Seat LED's - COBB Springs - JDM RainGaurds - TC Customz Single 12" Fiberglass Sub Box - Apline 500w AMP/12" Type R Subwoofer - Rally Armor Mud Flaps - Mazdaspeed SRI - Summer Setup - 5ZigenZR+ Wheels/Stock Rubber - Winter Setup - Stock Wheels/X-Ice Snow Rubber
Waiting To Get
Taillight Tint - LED Liscense Plate Lights - Forge BPV
GhostMercury is offline   Reply With Quote
Old 02-10-2008, 04:25 PM   #3
Bravnik
Registered User
Bravnik's Avatar
The install is very simple. It took me about an hour tops.
__________________
Old 02-11-2008, 02:22 PM   #4
Natedog_37
Registered User
So this is like a shift light just beeps instead of lighting up?
__________________
Nathan
2001 Eclipse GT PP "For sale $6,500"
1989 Conquest TSI SHP
2007 Honda Pilot
1998 Olds aurora "for sale $4500"
Ordered 2008.5 metro Gray Mazadaspeed 3
Natedog_37 is offline   Reply With Quote
Old 02-11-2008, 03:33 PM   #5
Bravnik
Registered User
Bravnik's Avatar
Yep same thing except you keep your eyes on the road and don't have an annoying flash hitting you in the eyes
__________________
Old 02-11-2008, 05:25 PM   #6
Moonpie.Express
aka Jamie
Moonpie.Express's Avatar
Donated: $20
07 Speed3, Cosmic Blue
Nice write up as always.
One thing though. Should it read "the 4th coil from the left"?
__________________
07 Speed3
Moonpie.Express is offline   Reply With Quote
Old 02-11-2008, 06:10 PM   #7
Bravnik
Registered User
Bravnik's Avatar
LOL - Thanks and fixed
__________________
Old 02-11-2008, 06:43 PM   #8
Moonpie.Express
aka Jamie
Donated: $20
NP - I was wondering if you had that special 5 cyl model.
__________________
Old 02-12-2008, 07:43 AM   #9
Mid_Life_Crisis
Registered User..of what?
Mid_Life_Crisis's Avatar
2007 MS3
Nice write up. It's funny, just the other day I was wishing I had the extra cash for a sending unit like this one. The difference is that I was going to locate a subtle LED at eye level in the A-pillar. I still have excellent peripheral vision so that would work nicely. I usually have my stereo going, so I'm not sure a buzzer would work for me. Would probably annoy me, "shut up damnit! I like this song! Now I have to rewind. Doggone it you made me miss my shift! Stupid buzzer!"
Mid_Life_Crisis is offline   Reply With Quote
Old 02-14-2008, 07:32 PM   #10
enganear
Registered User
enganear's Avatar
'08 Mazdaspeed 3 Sport, Sunlight Silver
My shift light triggered just fine off the 4V logic signal going to the coil without spending $40 on a booster. I made the connection at the wire going into the connector next to the battery box to avoid the environment under the TMIC. The wire to the LED array in the light can be spliced to pull a relay coil to ground and turn on anything you want like a beeper, or even to blow your horn LOL.
-enganear
enganear is offline   Reply With Quote
Old 02-25-2008, 01:12 PM   #11
dparm1984
boost FTW!
dparm1984's Avatar
2007 MazdaSpeed 3 GT
I take it this is similar to what the RX-8 has?
dparm1984 is offline   Reply With Quote
Old 02-25-2008, 02:05 PM   #12
Bravnik
Registered User
Bravnik's Avatar
Yep except fully adjustable shift points.
__________________
Old 02-25-2008, 03:41 PM   #13
07speed3
Registered User
07speed3's Avatar
2007 MazdaSpeed 3
Sounds cool...you have a vid of how it sounds...like how loud it is?
__________________
MS CAI, HKS SSQV-VTA,MSD DH, AWR MM, TWM shifter bushings, BFG G-Force T/A KDW's, CS DP, & CS RP, 20% tint all around, VHT Tinted side markers, third brake light, and rear reflectors, partially De-Badged.
Soon to come: cat back exhaust or modified stock cat back, TMIC or FMIC, AP or SB, and stage 3 clutch.
"There's no replacement for displacement unless you blow it real hard" haha
Maryland guys check out www.myspace.com/iconic_images
07speed3 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Project Done - Shift Beeper Installation Bravnik Mazda3/MS3 Car Audio & Electronics 5 02-10-2008 04:30 PM
to install or not to install.... slug420 NEPOC 9 03-06-2007 07:52 AM
clutch install, strut install, engine mounts, and other notes 71dsp Protegé 5 (Protege5.com) 9 03-07-2006 08:25 PM
New TWM Shift Knob Available Now! TWM Performance Protege, P5, MSP & MP3 For Sale 9 02-23-2006 11:01 AM
New TWM Shift Knob Available Now! TWM Performance MAZDASPEED3 & MAZDASPEED Axela (MZSPD3.com) 0 02-21-2006 08:37 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DISCLAIMER: Mazda Forums (Mazdas247.com), Copyright ©2001-2010, is a non-commercial organization for Mazda owners and enthusiasts. All content created by Mazda Forums users is for entertainment purposes only. Mazda Forums is not affiliated, related to, or endorsed by Mazda North America Operations (MNAO) or its parent company, Mazda Motor Corporation (MC) in any way. Material is used under Title 17 Chapter 1 Section 107 (Limitations on exclusive rights: Fair use) US Code. Use of trademarks is done on a fair use basis and without intent to compete with or take advantage of MNAO/MC or its trademarks. For more information on MC or MNAO, please visit http://www.mazda.com.
