![]() Show your support and Donate! |
| Off Topic Posts made here will not change your post count. |
Thread Tools | Display Modes |
#1 |
Registered User
Authorized Vendor
Truth about K-Sports?
![]() ![]() Brand New out of the Box. The Adjustment is for Rebound... http://www.ksportusa.com/asp/coilove...roduct_id=cd01 "36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment." I don't see any adjustment in compression ![]() In case no one understands, the forces labled at the Bottom of the graphs are the shocks at Full Soft and Full Stiff Settings. If you were to have one shock on full stiff and the other on full soft, the rears would almost match, but the fronts are out of control and just completely wrong. /Discuss
__________________
Jeff Wong Tri-Point Engineering 21345 Deering Court Canoga Park, CA 91304 Phone: 818-348-5385 FAX: 818-348-3823
#2 |
www.eleven5.com
Donated: $20
I wish I could really understand....thanks for the info.
#3 |
Crafty
Thank you thank you thank you. What a perfect way to expose what absolute garbage people are putting on their cars these days. It seems anyone that can machine some aluminum and put some pretty anodized colors on them are all of a sudden suspension experts. I wish we could make an official thread to expose these crap parts. I think many will be surprised or even feel indignation after exposing the suspension they thought was so super awesome as super worse than stock. Can you get some more samples on the dyno? How bout some teins, JIC's, and other jdm coilovers.
#4 |
www.eleven5.com
Donated: $20
Well we dont have to go to that extreme...I do use the Ksports and truthfully I dont do any autocross or run any type of solo events...but you have to also figure out that not everyone can go and get the best that is offered. Sure, I could have gone for TEINs or JIC, at the time I got this I didnt vision my car to be "all decked-out" and using the best I could find...but also they have done what I asked for. To stiffen the suspension and to give me the stance that I looked for. I have had them for over 12 months and have not had any troubles. Sure they may not stack up to the top suspension manufacturers but they probably where never meant to be, but at the same time they give options to people that couldnt get any of the expensive set ups.
On a side note...some of those JDM coilovers people drool over, are made on the same factory in China...some have 3 letter words.
__________________
Sigs are visible only in your first post on a page. To change your thread display preferences, click here and enable 'Always Show Signature'. |
#5 |
Crafty
Jeff question: Did you just go from what they specified as full soft and hard or did you test each set point on the shock? Testing each set point may be even more interesting.
The main problem I have with these is that they make them adjustable because of a bigger is better type of attitude. They could have just made it non adjustable and valved it(with a simpler valving mechanism) to work with the spring they provide and it would have worked better. I suppose flash is in. |
#6 |
bacon
so ideally, the graph should look like is has two lines, or two pairs of lines, each pair being real close each other?
#7 | |
mx3ownzj00
Donated: $10
Quote:
Ditto to the adjustment for the sake of adjustment comment... what else is there to say, the graph says it all!
__________________
#8 |
Crafty
Here is a graph I'm more familiar with. It has velocity as the x axis. These buddy clubs look pretty good!
#9 | |
Æquitas Veritas
Donated: $35
Quote:
__________________
#10 |
手前の言葉が俺は聞き捨てよう
if I'm understanding this correctly:
bound rate (line at the top bit of the graph, above 0) is fixed and is pretty much flat across the board regardless of piston speed hovering at around 145lbs for rebound, you're exerting a negative force... meaning you're pulling on the piston... force to pull the piston increases (ideally in a linear fashion IIRC) as it travels a certain distance
__________________
TheMAN '01 BJFP MT '05 BK3P HB AT For Protege and Mazda3 info, come see the Protege FAQ |
#11 | |
手前の言葉が俺は聞き捨てよう
Quote:
__________________
#12 |
手前の言葉が俺は聞き捨てよう
on a different note, I would definately like to see how the following perform:
stock MP3 stock MSP tokico HP tokico illumina JDM mazdaspeed a-spec adjustable (by tokico & KYB)... the only ones in this list which I have advertised rates on, which would be interesting to see on a dyno
__________________
#13 | |
mx3ownzj00
Donated: $10
Quote:
__________________
#14 | |
Æquitas Veritas
Donated: $35
Quote:
__________________
#15 |
手前の言葉が俺は聞き捨てよう
the variances between those 2 shocks are enough to cause weird handling effects when the car is driven at its limits
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toyota FT-HS Hybrid Sports Concept | mikeyb | Automotive News, Articles & Pics | 13 | 01-03-2007 10:19 PM |
| Toyota Aurion Sports Concept Unveiled (AU) | mikeyb | Automotive News, Articles & Pics | 38 | 11-09-2006 08:41 AM |
| New Lotus Elise Sports Racer | mikeyb | Automotive News, Articles & Pics | 1 | 10-22-2005 12:03 PM |
| Mercedez-Benz B-Class: The Compact Sports Tourer | mikeyb | Automotive News, Articles & Pics | 2 | 05-14-2005 10:59 PM |
| Mercedes-Benz Sports Tourer at the 2004 Paris Motor Show | mikeyb | Automotive News, Articles & Pics | 4 | 09-13-2004 08:35 AM |
