- 2017 Shelby GT350
There are two types of wheel & tire calculators below, choose one you like...
Yaggie1 said:Nice find. It's nice to be able to use that as a visual showing how the offset works and whatnot.
MyZmZm said:Same thing can be found here http://www.miata.net/garage/tirecalc.html
Hmm, interesting. According to this thing I could probably run some 225/45R16's on the P5.
*Runs out to measure car*
LOL, 4 month bump? Yep, I understand tires are all different and that more often than not 225 is not 225 mm - Azenis are wide as hell! Yeah I plan on running a similar setup to Rogue's old one (the Rotas, etc.) should work, just need money...*sigh* Tire sizes are no where near exact. See 205 Falken Azenis RT-215 and 615s and 195 Bridgestone Potenza RE-01R. Just because you have 225 mm of space under there doesn't mean the tire will actually fit. It's just like shoe sizes. Hell, I tried on 2 pair of sketcher yesterday. 1 size 10 fit perfect. The other size 10 was about 1/2 size too big. The same goes for tires. Different brands / models have their own fudge factor. Also, the width of the wheel the tire is mounted on plays a great part in the final proportions of the tire (ie, percieved tread width, how tall it is, etc)
(deadhorse
That being said, with the right offset 16x7 wheel, I've seen a 225 45 16 Hankook RS2 Z212 fit on the P5.
