Visit TeamMFactory.com for the best Mazda transmission components!
Results 1 to 9 of 9
Thread: Fuse for Cigarette Lighter
  1. #1
    Registered Member Alan's Avatar
    Mazda Protege 5
    Join Date
    Oct 2004
    Location
    Truro, Nova Scotia
    Posts
    6
    I was told that the cigarette lighter is powered off the radio. I have power to my radio, but the lighter socker doesn't work (I tried both the lighter itself and my cell phone adaptor). My dealer hasn't been particularly eager to help out.
    I tried replacing the yellow (20 a) fuse on the top of the interior panel, without luck.
    Any other suggestions?
    Thanks folks,
    Alan
  2. #2
    Registered Member 323CiP5's Avatar
    Protege5
    Join Date
    Sep 2003
    Location
    Ca, Ab
    Posts
    545
    loose wire?
  3. #3
    Mazda Protege 5
    Join Date
    Oct 2004
    Location
    Truro, Nova Scotia
    Posts
    6
    Is there an easy way to check for loose wiresb?
  4. #4
    stop honking I'm surfing Poseur's Avatar
    Donated: $20
    03.5 Lsr Blue P5
    Join Date
    Oct 2003
    Location
    Richmond Beach, WA
    Posts
    3,032
    cig ligther is NOT powered off of the radio one, it's a seperate fuse that makes little sense. I can't remember which exact one it is, but I believe it's a red fuse. It's been posted somewhere, but after I dig around in my car I'll postback if you haven't dfound it yet.
    Carputer work in Progress...
    Athxpmobile2200+, MSI kt6v-lsr MB, opus 150w dc-dc, 512ram, dvd/cdrw, bluetooth, wifi, XM...Installed and near-daily functional since 4/12/05
    Audio:
    Eclipse CD8454 HU, 14g wire pulled to doors toreplace my quad vifa 4's. 3-way setup with kicker SS56.2component set in kicks and Kicker SSMB8 (8" midbass) in door Amps: Avionixx NXD2400M. AXA600.4, MonsterCable/Phoenix gold wires. Sound deadening/carpetpadding everywhere. 12" Eclipse 7324 Alum squeezed into a 1.2cuf f/g box Misc electrcal:Code PC70 2-way alarm (remotestart, windows, snrf) w/autoloc window modules wired for one-touch up all around, AC/fresh air defrost switch disabled. Blue&Red LED's for ac/defrost/fresh/recirc lighting. retained window/sunroof power, one-touch sunroof, 1sty's Groundwire kit, Optima Redtop Exterior:Yakima rack (I'm a bike/board geek it's necessity), '03 MSP wheels, Espelir springs, Protege5.com stickers, 20/30% tint, DaveB "Protege5" shorty Antenna, Simple bicycle co. stickers Protege Garage custom dex-made hood prop kit Interior:B&M short shifter w/shaundarbie shortshifter boot, Wet Okole neoprene seatcovers, DaveB's brushed finish instrument rings.
  5. #5
    Registered Member
    2000 Mazda Protege LX
    Join Date
    Aug 2004
    Location
    Ohio
    Posts
    15
    look in ur manual for the fuse box descriptions it'll probably be called Aux Power Socket or something to that sort....
  6. #6
    gone user toucci's Avatar
    '03.5 Protegé 5
    Join Date
    Jul 2003
    Location
    San Diego
    Posts
    2,247
    it's a yellow 20a fuse in the kickpanel fusebox, I believe in the middle of the top row
    I had to replace mine when a defective power inverter blew it
  7. #7
    Registered Member M2P503's Avatar
    2003 Mazda Protege5
    Join Date
    Aug 2011
    Location
    Long Island
    Posts
    711
    Hello Toucci My 12 volt Cigarette lighter is out also im going to try to replace the 20 amp fuse that you are talking about in the Top middle and see what happens. Hopefully that works!
  8. #8
    2003 Mazda Protege5
    Join Date
    Aug 2011
    Location
    Long Island
    Posts
    711
    I checked that 20 amp Fuse you were talking about and to no avail did it fix anything. The Fuse was still good but My Cigarette lighter is still broken. How do i fix this stupid thing?
  9. #9
    Registered Member Jordysoso's Avatar
    2003 Mazda Protege5
    Join Date
    May 2011
    Location
    Amherst, Ohio
    Posts
    1,571
    Is there a wiring diagram for the cig lighter? I am wiring up gauges and would like to tap it for power.
    2003.5 Mazda Protege5
    http://www.mazdas247.com/forum/showt...44#post5910444
    Tired of rising gas prices?
Similar Threads
  1. How To: Electric Window Always On
    By jrodhotrod in forum Mazda Tech & How-To
    Last Post: 03-27-2013, 12:24 AM
  2. How To: Moonroof Always On
    By ZapWizard in forum Mazda Tech & How-To
    Last Post: 12-22-2008, 07:54 PM
  3. switched fuse for extra lighter outlet
    By eepr5 in forum Mazda Tech & How-To
    Last Post: 03-03-2006, 03:27 PM
  4. Electric Window Mod
    By Reitrof in forum Protege5 Lounge
    Last Post: 10-29-2003, 02:04 PM
  5. what fuse does the cig lighter run off of?
    By silver4 in forum Protege5 Lounge
    Last Post: 07-20-2003, 10:47 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
