VersaTuner - tuning software for Mazdas
Page 1 of 16 12311 ... LastLast
Results 1 to 15 of 238
Thread: Speaker Sizes, Harnesses and Kits of all Mazdas
  1. #1
    Pickle Pickle 1sty's Avatar
    Donated: $25
    2006 Toyota Tundra DC
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    Cool Speaker Sizes, Harnesses and Kits of all Mazdas
    SPEAKER SIZE:
    NOTE! 5x7"s and 6x8"s speakers are totaly interchangable as far as aftermarket speakers are concerned. So if you have a car with 5x7" speakers you can replace them with 6x8" speakers.
    OVAL vs. ROUND: Many Mazdas come with oval (5x7",6x8",6x9") shaped speakers. If you want high-end components you may find they only come in 5.25" and 6.5". The good news is that you can install these with a little extra work. See this how-to for details on installing 6.5" speakers.
    You can also purchase abs plastic adapters but these will not account for mounting depth issues with large drivers.
    2003 Mazda Speed Protege
    Front 5x7" @ 2.75"
    * Can use 6x8"s, see note above.
    * Can also use 5.25"s or 6.5"s with additional work, see note above.
    Front seperate tweeters by mirrors.
    Rear 6" @ 4.25", 6" speakers fit the best and 6 1/2" can fit by cutting the rain guard.
    2001-2003 Protege Sedan
    Front 5x7" @ 2.75"
    Rear 6x9" @ Over 8"
    2002-2003 Protege5
    Front 5x7" @ 2.75"
    Front seperate tweeters by mirrors. (2002.5-UP P5)
    Rear 6" @ 4.25", 6" speakers fit the best and 6 1/2" can fit by cutting the rain guard, Thanks Sir Nuke.
    1998-2000 Protege Sedan
    Front 5x7" @ 2.75"
    Rear 6x9" @ Over 8"
    1995-1998 Protege Sedan
    Front 6.5" @ 2" *
    Rear 6x9" @ Over 8"
    Dash Kits:
    1990-1994 Protege/323
    Front 5.25" @ 1.75" *
    Rear 5.25" @ Over 8"
    2003-UP Mazda 6:
    Standard
    -Front 5x7"
    -Rear 5x7"
    -90 amp alternator
    Bose
    -Tweeters - 1" @ 2ohms
    -Midrange - 6.5" @ 2ohms, can also use 6x8" or 5.25"
    -Rears - 5.25" @ 2ohms, can also use 6x8" or 6.5"
    -Sub - 9"
    -120 amp alternator
    -Door speaker amp: under the passanger seat
    -Sub amp: Built into the sub basket
    2004-UP Mazda 3:
    Front 5x7"
    Rear 5x7"
    HOW-TO: Mazda3 Front Speaker Install
    2006-UP Mazda 5:
    Front 5x7"
    Rear 5x7"
    Front door speaker depths are the distance to the windows not the deepest speaker usable!
    WIRE HARNESS:
    2004-UP Mazda 3
    METRA: 70-7903
    Peripheral: PESWIX universal steering wheel control adapter
    * I haven't tested this but they claim it supports all Mazdas
    * Please note, it requires an aftermarket HU with a IR remote control.
    * Check your HU manufacturer's website for integrated solutions before
    buying this unit.
    Metra: 70-7903, 71-7903 into factory radio -- these are female connectors
    Scosche: MA03, MA03R into factory radio NO DIMMER OR ILLUMINATION These are male (reverse) connectors
    Best Kits: None listed
    2002-2003 Protege5
    1995-2000 Protege Sedan
    Metra: 70-7901
    Scosche: MA02, MA02R into factory radio
    Best Kits: BHA-7901
    Metra: 70-7901
    Best Kits: BHA-7901
    2006-up Mazda5
    Metra: 70-7903
    Details for the wiring harness
    DASH KITS:
    2004-UP Mazda 3
    Scosche: MA1536
    METRA: 99-7504
    2003-UP Mazda 6
    METRA: 99-7503
    The navigation tray or glove box can be used to house and aftermarket unit.
    Metra: 88-00-9000 or 98-7599 (pockets)
    Metra: 99-7505 (full kit, see photos)
    Scosche: MA1537
    Best Kits: BKMA1573B
    Stock MP3 and MSP Pocket: BJ1H-66-9M0
    Stock MP3 and MSP Support Bar: TA06-66-9B1
    2002-2003 Protege5
    Scosche: MA1537
    Best Kits BKMA1573B
    1995-2000 Protege
    Should be din sized an not need a kit at all. Pockets are listed below!
    Metra: 99-5510, 99-5512, or 99-5700
    Scosche: FM2157
    Best Kits: None
    Metra: 98-7599 or 99-7500
    Scosche: MA1530
    Best Kits: MZ7 (metal)
    2006-up Mazda5
    Metra 99-7509
    Scosche MA1538B (to be released)
    INSTALLATION
    RADIO REMOVAL TOOLS:
    The radio removal tools are Ford radio remove keys. They are simply a set of U shaped metal. For a 2001 and up protege you will need 2 sets of tool, thats 4 U's
    They are availble for a few dollars at Autozone, Walmart, ect.
    STOCK PROTEGE MP3 REMOVAL TOOLS:
    These can be bought from :
    Kenwood parts dealers
    These are the actual removal tools
    Z919 removal tool
    Also a #4-40 x 1" Machine screws can be used aswell, Thank LinuxRacr for this one kids!
    STOCK MAZDASPEED PROTEGE REMOVAL TOOL:
    Seems Mazda was finaly kind to someone!
    The MSP simply uses standard Kenwood radio removal tools.
    Many stereo shop might lend you a par or you can call a Kenwood parts dealer, Kenwood parts dealers, and order some.
    STOCK P5 HEAD UNIT PIN OUT:
    Pic from:
    http://www.astolfo.com/p5/p5install.asp?track=5&mode=1
    Pin #: Wire Color - Use
    Pin 1: Green / Orange - Rear Right Speaker (-)
    Pin 2: Green - Rear Right Speaker (+)
    Pin 3: Brown - Rear Left Speaker (-)
    Pin 4: Brown / White - Rear Left Speaker (+)
    Pin 5: White - Front Right (-)
    Pin 6: Red - Front Right (+)
    Pin 7: Black / White - Front left (-)
    Pin 8: Black / Brown - Front Left (+)
    Pin 9: Black - Ground (see note below)
    Pin 10: Pink / Black - Switched power, coonect to red wire in aftermarket harness.
    Pin 11: White / Blue - Dimmer, not typicaly used for an aftermarket radio
    Pin 12: Green / Black - Illumination, thanks twizyours
    Pin 13: Blue / Red - Contasnt Power aka Battery aka Memory, connect to yellow wire in aftermarket harness.
    NOTE: For aftermarket units, bolt ground wire directly to frame of car instead of using chassis ground wire on harness. Using the harness ground almost always introduces alternator whine.
    STOCK MAZDA 3 HEAD UNIT COLOR CHART
    White/Black = left front +
    Gray/Black = left front -
    White/Red = right front +
    Gray/Red = right front -
    White/Purple = left rear +
    Gray/White = left rear -
    White = rear right +
    Gray = rear right -
    Orange/Black = 12v constant
    Orange/Black with silver dots = 12v illumination
    Yellow with silver dots = 12v switched
    Black/Green = Chassis ground (see note below)
    PARTS
    BUYING ONLINE
    CRUTCHFIELD: If you order a head unit or pair of speakers from crutchfield they will send you all the necessary installation harnesses, kits, and instruction sheets free of charge. They have excellent customer service and will answer any and all questions regarding the installation of your new gear. Shipping costs are reasonable and they are an authorized internet retailer for all the products they sell. That means you will get the full manufacturer's warranty should something go wrong.
    SOUNDDOMAIN: Sounddomain also has excellent customer service but not quite as good as Crutchfield. They are also an authorized internet dealer for everything they sell and often have equipment at discounted prices over Crutchfield. You can also find some sweet deals on discontinued products and factory refurbished equipment. Shipping costs are reasonable but they won't hand out freebies like crutchfield. You will have to pay for the installation kit and wiring harness and that can be the deciding factor when price-matching with Crutchfield.
    MOBILESQ: MobileSQ.com is authorized to sell high-end equipment from Brax, DLS, Helix, and Seas only if there is not an authorized dealer in your area. These brands are not widely known so the chances of there being a dealer within 50mi of your home is pretty slim. Going on the feedback from others and not personal experience, they also have excellent customer service and competitive pricing.
    eBAY: eBay sellers are NOT authorized vendors. You do not get a manufacturer's warranty so any and all warranty service is at the discretion of the seller and his/her technicians. Since they are not authorized to sell online, the equipment they put up for auction has the potential to be used, refurbished, or B-stock (items that did not pass the manufacturer's test specifications). Many items sold as new have manufacturer serial numbers scratched off to prevent the item from being traced back to the original dealer. Such items can never be serviced by the manufacturer. So with that information in hand, please bid carefully on eBay and be cautious when bidding on NIB equipment from turbo sellers.
    MECP certified Installer, Infocomm CTS-D certified System Designer
    2009 Nissan Xterra
    2010 Hyundai Genesis Coupe 2.0T
  2. #2
    Master of ALL Things :{D Sir Nuke's Avatar
    Join Date
    Mar 2002
    Location
    Southeast Texas near Houston
    Posts
    3,414
    1st, the scosche harness is listed in their books for the 2001 up only as the MA03......their REVERSE harness to plug into the back of the stock head unit is the MA03R.
    the FRONT STOCK speakers are in fact 5 X 7's....but the 6 X 8's will fit right in. I personally used 5 X 7's for one reason or another.
    the REAR STOCK speaker size in the 2002 P5 is in fact 6" the ONLY modification that will be needed to put the 6 1/2 in the rear door is to the rain guard that is on the stock speaker IF you want to reuse them. also the stock speaker has a STRANGE three screw pattern, they are NOT 120 degrees apart as you would think...and there may not be a speaker out there that has the exact pattern in them. the speakers I replaced my rear door speakers with were 6 1/2's and even thought they had about 50 different screw locations in the ring of the speaker frame...NONE of them matched the door....so I just drilled two new holes in the speaker frame....NOT the door.
    and although the ACTUAL back spacing for the speakers to the window in the front is 2.75 inches....at that depth the speaker IS TOUCHING the window.
    and best kits lists their harness as 70-7902 for the P-5.
    there is also American International...but i can't remember their number off of the top of my head.
    '02' Vivid Yellow P-5 / 5-Speed / MoonRoof / Rota Battles with Yokohama ES 100's 215/40/17 / Tinted Windows / Bosal Cat-Back / Injen CAI / B&M Short Throw Shifter/kartboy Bushings / Eibach Pro Kit and....oh yeah, and that BAD Ass flaming skull on the back quarter windows!
    2010 Rally Sport Camaro. Infero Orange Matelic, 312 h.p. V6, White Rally Stripes, 20" Polished wheels, 6 speed Automatic w/ manual over ride that has paddle shifters, Boston Acutics 250 watt / 9 speaker sound system, USB PORT, full guage package (no idiot lights), HID's, halo lights around the head lights, blacked out tail lights, rear spoiler, special interior package (two tone leather, black w/ orange insert in the middle, orange inserts on door panels that up to the front of the door and then across the dash, special orange accents in the gauges, and all the stiching on the seats, doors, and the shifter is orange.) :{D
    and thanks to Enry I have my own smile
  3. #3
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    I wil majke the changes to reflect your comments. All spacing and speaker size was derived from crutchfiled. Metra numbers were from Metrausa.com and bestkits from beskits.com.
    I'm not suprised the Best kits numbers in the book for 01' s are wrong as metras was only a week or to ago also and bestkits seems to just resell metra. 7903 is definitly right for metra. I verified it at Tweeter.
    I wil check scosche's website to verify there numbers.
    I believe 5 1/4s will fit the rear door if you remove the plastic mounting aperatise, but I'm not sure. I haven't installed in one yet.
  4. #4
    Join Date
    Mar 2002
    Location
    Posts
    3,414
    the metra and scosche numbers I got directly from each of the specific manufactures....NOT a book...OR their websites...but after MANY calls on the phone to both places.
  5. #5
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    Metra i have viausly verified and the website lists as 7903, since Best kits is a knock off there number should also be 7903. The Scosche numbers were per sounddomain and scosches website. Sounddomain added a B at the end thats all. I don't think anyones into radio adapter is ready to ship yet.
    Take another look and make sure it all looks koshier. The Best kits number which is our only discrepency is right per there web site. And that websites drwring is exactly what it need to be for a 2001 and up protege. Metra was originaly listing the 70-7901 for 2001 mazdas then they realized they changed them. We'll that actualy happened when i called them over a year ago and told them about my MP3. They only corrected it a short while ago.
  6. #6
    calmest cat on the board blynzoo's Avatar
    Donated: 10$
    '02 Red P5...BUT AS OF 1/31/08 an '08 Silver SPEED3!!!
    Join Date
    Feb 2002
    Location
    Washington, DC
    Posts
    1,412
    Good to have you here, MP3. Smart mo'fo.
    U2, you old codger!
    --Your Man B
    DISCLAIMER: All Mazda corporate employees, Mazda dealerships, Mazda service personnel or employees, family, friends, or acquaintances thereof: This in no way constitutes an admission or acknowledgement of tampering, modification, usage, or alteration of any vehicle in my possession or component thereof in such a fashion as to void, cancel, deny or otherwise refuse service on any service contracts, warrantees, or recall notices covering said vehicles. This and other posts submitted on this, or any Internet forum, under the screen name "blynzoom" simply represent an attempt to gain acceptance from a peer group espousing cars of a high performance nature - especially those that have been altered to improve, enhance, or otherwise modify the automobile's natural characteristics. Any statements, claims, or graphical representations made that would constitute a violation of any contractual agreement are to be considered fictitious and not to be accepted in any court of law, or similar environment mediated for the purpose of dispute resolution.
    To report problems with a Mazda dealer, or report a problem to Mazda that the dealer will not fix, PLEASE contact Mazda NA at http://www.mazdausa.com/MusaWeb/contactMazda.action .
  7. #7
    Registered Member
    Join Date
    Nov 2002
    Posts
    10
    what about the tweeters in front? has anyone replaced them?
    87 Mazda RX7 Turbo II (Modded and broken)
    02 Mazda Protege 5 (All stock and runnning well) ** FOR SALE**
    95 Chevrolet Camaro Z28
  8. #8
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    what do you need to know about them?
  9. #9
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,863
    Re: Harness, Kits and speaker size of all Proteges!
    Pin 12: Green / Black - n/a
    Question: Pin 10 above, could that be used to turn an aftermarket amp on / off? (if i get an aftermarket amp, would that lead be tapped for the amp's power switch?)
    Nik
    2011 Black MX-5 GT
  10. #10
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    Your right one my Brotha form anotha motha!
    Typicaly with a stock headunit we splice the amps remote line into the switched aka accessory power at the radio. If you turn the radio off but the car is on then the amp stays on. But its better then a switch that if you forget to turn it off you end up draining the battery.
  11. #11
    Registered Member dmitrik4's Avatar
    '04 RX-8 || '10 CX-9
    Join Date
    Aug 2002
    Location
    Phillies-delphia
    Posts
    2,369
    any details available would be helpful...for example:
    power rating? size? can/should i buy replacement tweeters? or when i install an aftermarket HU, can they handle it? how are they connected to the stock HU...i don't see a pin for them, so when using a 4-channel HU are they just drawing power from the front speakers' signal?
    it seems odd that there is no mention of these tweeters anywhere. i was beginning to think i had a "special" Pro!
    mike #44 CS
    '04 RX-8 - daily and racer
    '10 CX-9 - family truckster
    www.GreyhoundAngelsAdoption.com
    www.phillyscca.com
    Quote Originally Posted by Jalopnik
    We'd rather be taken out and shot behind the storage shed than spend $28,000 on a perfectly competent automobile that delivers very good fuel economy.
  12. #12
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    The stock tweeters I am assuming use a higher impedance then 4 ohms so they don't cook the factory head unit. I haven't gotten the chance to meter one however. Since most tweeters in the aftermarket are 4 ohms when run in parallel with the mids the low impedance may cook the radio. its always best and safest to replace the mid and tweeter at the same time with a component set.
  13. #13
    Registered Member
    Join Date
    Dec 2002
    Posts
    10
    Hey Guys, can anyone confirm where if there is a pin in the stock wiring harness for the Antenna control wire? I recently got a new hu and connected the blue antenna control wire on the hu's harness to the blue wire on the metra harness. Since the p5 does not have a power antenna, is this dangerous? Will it cause any problems? Do you know where the connection would terminate at? To the fusebox? Thanks!
  14. #14
    Join Date
    Aug 2002
    Location
    Phillies-delphia
    Posts
    2,369
    thanks for the suggestions guys.
    what do you think?
    Amp: Alpine MRP-F320 40WX4, 120WX1, $250 from Crutchfield
    Front Components: Kenwood KFC-P683C, 6"X8" + 3/4". $160 from Crutchfield
    Rear Deck: Kenwood KFC-6905S, 6X9 $80 from Tweeter.
    Sub: here's the question. the 10s seem to need too deep a box...One 8" might work better. and be cheaper than 2 6s...
    JL Audio 8W3, 125W RMS, $150 from Tweeter.
    does anyone know anything about the 8W04? it's not listed on JL's site. it's a lot cheaper ($80), but is rated at 100W. so the 125W channel should still be ok?
    the box that JL describes is 16X9X6.8...but 16X11X5.6 gives me the same volume. from what i've read, box geometry doesn't matter as long as you end up w/ the same volume. correct?
    i would probably end up having to do this a piece at a time, and then maybe just install everything at once when it gets warm out again...looks like i can do it for under $750. hopefully.
    thanks for your help...
  15. #15
    Donated: $25
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    I like the amp, I don't like the speakers but as I have said thats on a per person basis as long as you like them for you then so do I. They should be a nice match with the amp though. You can get all this stuff from tweeter though. They should be able to order all of it. I don't remember a 10W3 being much deeper then an 8W3. You can have one of my 8W3s for $75 if you like. They are a year old and I only used them for 4 months. They are dual 2 ohm subs so they can give you either a 4 or 1 ohm load.
    Box volume and sealing is all that is really important. After that its typicaly said to have atleast 1" behind the magnet in the box before the rear wall. An 8w0 will do fine with the amp.
    what do you think?
Similar Threads
  1. Replies: 9
    Last Post: 09-12-2013, 12:15 AM
  2. Speaker Sizes, Harnesses and Kits for the Mazda3
    By chuyler1 in forum Mazda3 Audio
    Last Post: 07-15-2013, 07:25 PM
  3. Speaker Sizes, Harnesses, and Kits for the Mazda6!
    By chuyler1 in forum Mazda6 Audio
    Last Post: 08-24-2012, 09:50 AM
  4. Speaker Sizes, Harnesses and Kits of all Mazda Proteges
    By chuyler1 in forum Protege Audio
    Last Post: 04-12-2006, 10:50 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
