emergency brake light on
shoelessdavis
Mazda Mp3 #810
I am having problem with my emergency brake light coming on when I push the brake/use brakes. The emergency brake is off/down and I will be driving down the road and stop a stop light and the brake light will come on. This is on my mp3. I have not had any problems with brakes before. The brake pads are fine and have plenty of pad left and I checked brake fuild and it is fine. I have 45,000 miles on my car and my factory warrenty is up/no good as of last month. what could problem be?
The fluid level may be fine when you remove the reservoir lid, but when you press the brake pedal, it may draw down just enough to trigger the sensor. I'm with Savy, check, and top off, the fluid level.
