Sensor in the manual transmission
peepsalot
Contributor
Black 03 MSP
What is the sensor for that goes into the manual transmission? It is located between the drain and fill holes of the tranny fluid. Is this the rpm senser for the tach?
speedo sensor: very close to the block towards the rear of the housing(top side).
EDIT: the one on the underside near the drain plug is the reverse light switch.
im pretty sure the speedo is on top of the tranny, im not sure which one is between the oil drain/fill.
