Show your support and Donate!
Results 1 to 9 of 9
Thread: Cylinder 3 misfire?
  1. #1
    It's almost paid off! simdrew's Avatar
    2003 Mazda Protege
    Join Date
    Jan 2004
    Location
    Michigan
    Posts
    191
    Question Cylinder 3 misfire?
    Does anyone know why I get a CEL code for a cylinder misfire? What could be causing this? The spark plugs have less than 8k miles on them, so do the wires. I have a pretty open-ended exhaust, could that be the problem?
  2. #2
    2003 Mazda Protege
    Join Date
    Jan 2004
    Location
    Michigan
    Posts
    191
    BUMP anyone?
  3. #3
    Gothenburg Superiority Installshield 2's Avatar
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,057
    lots of things can cause a misfire...and other codes thrown with the misfire? I assuming you had some way to know why the MIL was on, so a reader or something?...
    could have just been a one time thing though...it doesn't necessarily mean you have a problem....a lot of times it can be caused simply by a bad shot of gas into the cylinder...with a little moisture or impurities...
    what type of conditions did it occur in? on a hot day with the AC on at low rpm or something?...the conidtions may help find why it happened...
    "I am a Union Delegate" -Henry Hill '63
  4. #4
    Baby replaced my P5! WAH! ddogg777's Avatar
    2002 Yellow P5
    Join Date
    Jun 2003
    Location
    Hot arizona!
    Posts
    1,917
    My Malibu has a no#2 cylinder misfire. The tech hooked up the obd computer and a fuel pressure gauge to the fuel rail. He then fired each injector individually and you could see the fuel pressure jump and the hear the injector click. Long story short, all the injectors but #2 were working.
    Other causes:
    spark plug
    spark plug wire
    coil pack
    2002 Protege5 for sale, 31000 miles.
    "...for if they humble themselves before me, and have faith in me, then will I make weak things become strong unto them." --Ether 12:27
  5. #5
    Registered Member s5number2's Avatar
    Join Date
    Aug 2004
    Posts
    15
    try this my lx had the same problemit hasn't returned for a while
    http://www.msprotege.com/forum/showthread.php?t=77755
  6. #6
    Original Member
    Donated: Stopped $5/mo
    Afghanistan Moderator
    2016 MX-5 Club, Ceramic
    Join Date
    Jan 2003
    Location
    Honolulu, HI
    Posts
    16,167
    i had the code once, it was due to my washing my engine bay and i had water in the cylinder, above the spark plug, i used some vaccum line and sucked the water out - problem went away.
    Ceramic 6MT ND Club - 17x8 Advanti Storms/RSR Coilovers/CorkSport F&RSB/GWR midpipe & SuperQ/OFT header & tablet - Pics on IG @Matth3wAJ
  7. #7
    Banned Brian MP5T's Avatar
    Donated: $5
    MP5T / 944
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    10,904
    Yikes...
  8. #8
    Banned SpicyMchaggis's Avatar
    Donated: 5$
    Join Date
    Apr 2003
    Posts
    6,068
    look on the brightside..at least you haven't succumb to bent valves..many FS-DE's have fallen victim to over-rev and wasted valves..cams keep going more and more teeth back and eventually you just blow the motor..
  9. #9
    MAZDASPORT AZ member dawick777's Avatar
    2002 Silver MP5
    Join Date
    Aug 2003
    Location
    Ahwatukee
    Posts
    315
    just brought my 5 in for a #1 misfire.....said it might be a burnt valve or something.....i replaced plugs, coils and wires...still no go
    so we'll see what they come back with
    MAZDASPORT
    2002 Silver MP5
    5-speed Manny
    03.5 MSP Front Bumper and Lip
    Eibach Pro Kit
    JDM (style) Black headlights
    Shorty Intake w/ custom (homemade) cold air ram
    Mazdaspeed axelback
    "Anodized" Red Brake Calipers
    Custom grill (+5hp)
    MP5 badges (+10hp)
    Nokya Aluminium Pedals + dead (+7hp)
    DaveB's polished gauge rings
    DaveB's "MAZDASPORTS" antenna (AWESOME)
    _________________________________________
    ___________Alex______Bill____Christie____Jon _John____ Loren____ Andy_____ Eli
    ___________Truc
    MY CARDOMAIN PAGE!!!! ***UPDATED 1/14/04***
Similar Threads
  1. Protege 929 Master Cylinder Brake Upgrade
    By flat_black in forum Mazda Tech & How-To
    Last Post: 06-12-2016, 12:14 PM
  2. HELP cyl 3 misfire! QUICK!!!
    By DiS in forum Protege Performance
    Last Post: 07-07-2004, 01:07 PM
  3. HEre's what I want!
    By 1sty in forum Mazda Tech & How-To
    Last Post: 11-19-2003, 03:03 PM
  4. misfire?....
    By dominoy2k1 in forum Protege Performance
    Last Post: 10-17-2003, 01:52 AM
  5. sri rubbing on master cylinder
    By slcp5 in forum Protege Performance
    Last Post: 09-16-2003, 07:09 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
