Wagner shorty (or any header?) tightening issues?
Dimitrios
Contributor
2012 CWP MS3
Hey all,
I installed my Wagner shorty header over the weekend and while everything pretty snug, I have a hell of a time getting any sort of a socket or wrench into about four areas to tighten down the cap screws into the head.
Are all of the 2.0L headers like this? It's a bit disconcerting to have 4 bolts with unknown torque specs right now.
Anyone offer some advice or other info on this? Clearance like the OEM manifold would have been pimp. (peep)
D
Hmm..I looked at the OBX and it seems that they have more clearance for such matters...I'll pursue it a bit more.
When I installed my AWR header, I had two bolts like that. Just tightened them down as close to the others as I could get, and left it alone. There really isnt any room to do much better.
scorch70
If you're used to wrenching like I am, 14-16 ft/lbs is pretty easy to excede with a small hand wrench, so you should be pretty good. =)
Yah, I'm good with wrenchin'. I just somewhat felt a little oddballish about it all.
Now to just get the right sized ARP cap screws and I get to replace the stock stuff :D
Thanks guys.
see there are maximum torque specs for a reason. you should stay within them.
I wasn't concerned about exceeding the torque specs, I was concerned about getting enough on those difficult to access cap screws to get them within spec.
Awww....sorry man; I actually didn't intend to install it...I just started to remove the heat shield so I can check bolt sizes...then another bolt...and another....before I knew it I'm yanking the manifold.
If it's any consolation, I still have my H&R/Tokico Blues/AWR 19mm swaybar to install....
Have Questions regarding Wagner Header
I am ready to install my Wagner shorty header. I have a question regarding installation. What is a O2 and EGR Bung?
Big Dog
Big Dog
egr is up top by where the manifold mates to the engine block. egr = exhaust gas recirculation. its a small pipe with a nut that seals it to the header or exhaust manifold. the o2 bung is where your oxygen sensors go.
