Passenger Side Door Lock Switch
Mazda 2003 Protege LX
One annoying thing the Protege is that it lacks a button to unlock the doors from the passenger side.
First I purchased a matching switch from a forum user that was parting-out his protege.
Using the trim I made an outline of the switch hole.
Using an exacto-knife I cut out the cloth over the hole.
I removed the door panel, following my guide here: CLICK HERE
I then used a dremel to cut out the hole.
I took apart the switch to get at the electrical contacts.
I then soldered two wires to the contacts.
These wires will connect to the wires running to the Keylock on the outside of the door.
You will have to cut away some of the plastic covering the connector.
There is a Black/Blue wire, and a Green/White wire, I didn't take the time to trace which wire is ground, and which is the lock signal.
I instead tapped the wires, and if the button didn't work as expected, I would reverse them.
I then installed the switch into the new hole, and put the door panel back in place.
The new switch mirror's the driver's side switch, and allows my wife to unlock or lock the doors without reaching over to the driver's side.
Bookmarks
