Your Best Source for Genuine Mazda Parts!
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: Programming a Spare Remote for Mazda3
  1. #1
    Turd in the punch bowl goldwing2000's Avatar
    2004 Mazda3s Hatch; 269,000 miles
    Join Date
    Feb 2004
    Location
    Chandler, TX
    Posts
    6,316
    This was deleted, so I'm re-posting it:
    Step 1: Open driver side door and leave open.
    Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
    Step 3: Insert key into the ignition.
    Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
    Step 5: Close and open the drivers door 3 times. Leave door open after this step
    Step 6: ECU should respond by locking and unlocking the doors once.
    Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
    Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
    Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
    ~Kane
    Mods: ~Eibach adjustable rear camber links ~Red AEM CAI ~hot wired cigarette lighter ~130psi air horns ~10ga. ETB Ground ~Corksport SS Brake Lines ~Monzsta Timing Mod ~Spoiler Delete ~RDX Antenna ~Rusted-Out Rear Wheel Arches ~Hail Damage ~Frankenbumper
    Accessories: ~A/W floor mats ~cargo tray and net ~autodim r/v mirror with compass and temp ~rear bumper step plates ~mazda M/T pedal set
  2. #2
    Speling Champeon bvmazda3's Avatar
    Join Date
    Mar 2004
    Location
    Victoria BC Canada
    Posts
    255
    "... you do the hokey-pokey, and you turn yourself around ..."
    Bart
    Indigo Blue '04 Mazda 3 Sedan GT
    5MT - GFX - MP3 player - Mobil1 - Stubby - Cargo net - ETB ground - Dual horns
    Infinity Basslink - SilverStar signals - Int/Ext LED's - 215/45-17 Kumho Ecsta ASX
    Progress Tech rear anti-roll bar - 20/35% tint - Injen CAI - sok07 dead pedal
    THE SMOKE MUST NEVER LEAVE THE ENGINE BAY... ITS THE SMOKE THAT MAKES IT WORK.
  3. #3
    Join Date
    Feb 2004
    Location
    Chandler, TX
    Posts
    6,316
    Yeah, my original reply was, "it sounds like you're square dancing with your car."
  4. #4
    hickalicious!! tsunami's Avatar
    Donated: $20
    mazda3 5 door
    Join Date
    Feb 2005
    Location
    maine
    Posts
    5,110
    is this for just a keyless entry or for a new key...???
  5. #5
    Registered Member wongpres's Avatar
    Ti. Grey Mazda3 GT GFX
    Join Date
    Mar 2003
    Location
    Toronto, Canada
    Posts
    1,059
    This procedure is to program a new keyfob only.
    If you want to program a new key (i.e. program the immobilizer chip on a new key that will start the car), it is a different procedure.
  6. #6
    Donated: $20
    mazda3 5 door
    Join Date
    Feb 2005
    Location
    maine
    Posts
    5,110
    Quote Originally Posted by wongpres
    thanks just wanted to make sure.....
  7. #7
    Join Date
    Feb 2004
    Location
    Chandler, TX
    Posts
    6,316
    The procedure for doing a key is here:
    http://www.msprotege.com/forum/showthread.php?t=71178
  8. #8
    I live for the view! Mikey444's Avatar
    Mazda 3 & RX-8
    Join Date
    Jun 2004
    Location
    Montreal, PQ
    Posts
    2,089
    Does it work for the RX-8 as well?
  9. #9
    Join Date
    Mar 2003
    Location
    Toronto, Canada
    Posts
    1,059
    RX-8 is similar but slightly different. If you want it PM me.
  10. #10
    Virgin1, Rally White bbrich57's Avatar
    Mazda3, MS3 & Texas Moderator
    2004 Mazda3 HB
    Join Date
    Feb 2006
    Location
    Austin, Texas
    Posts
    3,175
    Mazda's Crash Test Dummies
    Quote Originally Posted by goldwing2000
    Step 1: etc.
    Step 384: ...You're done!
    Yup! I don't think we're in Kansas anymore Toto.
    (encourage
    Whew, that was GREAT!!!
  11. #11
    Registered Member
    Donated: $10
    Join Date
    Sep 2006
    Posts
    42
    Thanks for the post. I'm probably going to order a key fob tonight. It never came with my car. I didn't even know the car had an alarm system until yesterday (freaking dealer didn't know what they were talking about when I asked).
    Does anyone know what the alarm does? I'm thinking of going aftermarket anyway, but if the stock features are pretty decent, I'll probably just stick with it.
  12. #12
    2004 Mazda3 HB
    Join Date
    Feb 2006
    Location
    Austin, Texas
    Posts
    3,175
    Quote Originally Posted by mzdp5fan
    It's not made fully clear in the manual either, but it is an engine/starter deactivator. There is no warning siren/horn, that I know of.
    BTW: Some other posts I have read have stated that they had problems using an AM alarm system. The manual states that it could cause other problems too, and would give Mazda a good reason to selectively void your warranty.
    My advice, be careful if you go that route.
  13. #13
    Join Date
    Mar 2003
    Location
    Toronto, Canada
    Posts
    1,059
    The alarm is a very simple system. It'll just honk the horn and flash the blinkers if a door/trunk/hood is opened without previously having pressed the unlock on the remote (or physically inserting key into driver door or trunk). There is no shock sensor or anything like that.
  14. #14
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,577
    you'll know you have a stock alarm if you use your key to lock the doors and the blinders flash a second later
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    For Protege and Mazda3 info, come see the Protege FAQ
  15. #15
    Registered Member
    Join Date
    Jun 2007
    Posts
    1
    2005 Mazda 3 program remote keyless entry
    Will this work for a 2005 Mazda 3?
Similar Threads
  1. Programming new remote for keyless entry
    By LeeH in forum Mazda MP3 Lounge
    Last Post: 03-16-2005, 05:56 PM
  2. Replies: 1
    Last Post: 06-28-2004, 11:04 AM
  3. Amp remote turn on wire?
    By cynth in forum Mazda Tech & How-To
    Last Post: 01-20-2003, 12:03 AM
  4. Replies: 7
    Last Post: 11-28-2002, 06:58 PM
  5. remote start and factory alarm HELP!
    By davedag in forum Mazda Tech & How-To
    Last Post: 07-23-2002, 08:58 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
