Your Best Source for Genuine Mazda Parts!
Results 1 to 5 of 5
Thread: Need to know what size bolts and nuts for the exhaust manifold
  1. #1
    I'm back!!! ;) Subghetto's Avatar
    2008 Nissan Rouge; Former 2002 Mazda Protege 5 owner
    Join Date
    Oct 2003
    Location
    Long Island, NY
    Posts
    1,338
    I'am going to be installing the wagner header when I get it but I want to buy new bolts and nuts since mine are rusted to shit. So does anyone know the sizes? Also what are the sizes for the ones for the stock exhaust manifold that bolt on to the stock pre-cat?
  2. #2
    Registered Member Dimitrios's Avatar
    Donated: $20
    2012 CWP MS3
    Join Date
    May 2003
    Location
    Chicago
    Posts
    4,554
    All the Factory Service Manual has is torque specs: 14-16 ft-lbs for the flange to head, 28-38 ft-lbs for the pre-cat nuts. I'll do some digging too - I'd want new studs and nuts.
  3. #3
    Goddamn Electric sidpro5's Avatar
    2001 Dodge Ram 2500 SLT Laramie Quad
    Join Date
    Nov 2003
    Location
    Montgomery County, PA
    Posts
    940
    Dave, have you heard anything about when they are shipping the headers? I know they have to be fabricated yet............As far as the bolts/studs, I was thinking maybe I'd replace mine with ARPs if I can find them locally.....
    2001 Dodge Ram 2500 Laramie SLT/360/2" TGC level/BDS shocks/35" Kuhmo Road venture KL78/Recon Smoked Cab Lights and HMBL/Sony I.C.E/Nu Image white face gauges/Spectre CAI/8mm Taylor Spiro-Pro wires/Superchips tuned/Magnaflow hi-flow y-pipe & cat/Flowmaster 40 si/do/MT Classic II's/4.56 gearing/Uniden CB and scanner
    Zombie Response Team, Ground Assault Unit, Sector 7~~~~Member, PAFOA
  4. #4
    Join Date
    Oct 2003
    Location
    Long Island, NY
    Posts
    1,338
    Quote Originally Posted by sidpro5
    Seth, I went on www.protegeclub.com and got on the wagner group buy for the headers since fkmp5 informed me that it was going on over there, here is the thread-http://www.protegeclub.com/forum/sho...644#post294644 I was going to buy them from nick directly but I figured the group buy would be a quicker way.
    Now about the studs? how are they? are they sticking out or bolted in. My cousin said that they are hard as hell to replace on his car because you need a special tool or something and that it sucks if you break a stud off. I'am not sure how they are on the P5?? Anyone also know the size for the bolts and nuts I want to replace as much as the stock hardware as I can since it's really rusted to shit and want everything brand new since I'am getting a new header.
  5. #5
    Donated: $20
    2012 CWP MS3
    Join Date
    May 2003
    Location
    Chicago
    Posts
    4,554
    Subghetto - I installed my Wagner shorty yesterday.
    - All the studs (head and pre-cat) are M8 x 1.25 pitch x 40 mm (or so)
    - There are two studs in the head for the exhaust manifold; the rest are hex head cap screws (bolts).
    - The five in the pre-cat are difficult as hell w/o a torch or stud extractor to remove. I left mine but have eventual plans to replace them.
    I used M8 x 1.25 x 48 mm (1.75") long studs to replace the two in the head. I need to return my "kit" to Tony at AWR to get shorter 12-point cap screws and longer studs because the ones provided bottomed out on the head and couldn't tighten them properly.
    I ended up buying ARP-400-8013 stud kit from Summit last week and used two of them to replace the OEM ones in the head to header.
    See this PDF on ARP's site for more info: http://www.arp-fasteners.com/media/p...s/SC_54-58.pdf on the studs and http://www.arp-bolts.com/media/pdf_f...04nu_prods.pdf for the cap screws (see the items under "M8") on page 6 - kit 771-1005 (M8 x 1.25 x 40mm - 12 point cap screws - stainless steel) should work good.
Similar Threads
  1. How To: Mazda FS-DE Camshaft Installation
    By twilightprotege in forum Mazda Tech & How-To
    Last Post: 08-27-2013, 04:09 PM
  2. Cam install proceedure.
    By curt2go in forum Protege Performance
    Last Post: 07-06-2007, 04:12 AM
  3. manifold re-studing done!!!
    By smp3000 in forum Mazda Tech & How-To
    Last Post: 04-26-2004, 09:58 AM
  4. Loose nuts?
    By Gyre in forum Protege5 Lounge
    Last Post: 01-13-2003, 11:10 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
