Limited Edition
Hello,
I'm looking for the easiest way to remove the stock alarm LED located in our cluster. How does one remove this? I've looked at it, and there is a wiring that runs directly behind it (you can actually feel it, if you stick your hands behind the steering wheel column)
Does the LED slide out of the cluster? Or can i remove the wire some how?
